CLS Coupe (C219) Discuss the CLS Coupe.
Windshield Washer fluid level and/or coolant level sensor
Old 03-27-2014, 01:45 AM
buzescu's Avatar
2008 CLS550, 2001 C240
Does anyone know where the windshield washer level sensor and the coolant liquid sensor are located?
They are on the same circuit and sometimes trigger false alarms .. they are very cheap but I can't find where they are.
Anyone had to replace either one?
Thanks,
Old 08-18-2014, 12:58 PM
Roydavis's Avatar
2005 E350
The coolant sensor is under the header tank. You just twist to remove it and unclip the cable. I don't know where the windshield washer level indicator is. I am trying to find out myself.
Old 12-02-2014, 10:26 AM
willlib's Avatar
ML320 CDI 2008
winshield level sensor
it's located under the left fender couples of bots to take off very easy to change. but I thinks your problem are not the sensors it may be related to SAM. because coolant and windshield level sensor are on the same circuit. I got a similar problem. I changed my windshield washer sensor and it did nothing the problem is still there
Old 12-02-2014, 12:45 PM
Roydavis's Avatar
2005 E350
Windscreen washer or coolant level indicator
I tried replacing both the coolant level and windscreen washer level sensors but it still shows 'check coolant level'. The coolant level is fine. I have concluded the same as you. It is the front SAM unit unit. In SA this will cost about $900 to replace with a new one. I may go for the used one I was offered for about $200 but have to install it myself. Has anyone installed a front SAM unit.
Old 05-03-2015, 12:31 AM
buzescu's Avatar
Sorry for my ignorance. What is the SAM unit?
Old 05-03-2015, 02:30 AM
Roydavis's Avatar
2005 E350
The coolant sensor is situated under the front of the header tank. It clips out by turning it. The washer level sensor is right down by the washer tanks. It is not easily accessible.
If you but a used front SAM unit it must come from the same car or the agents will have to program it.
Old 05-06-2015, 10:29 PM
c240classic's Avatar
2007 cls63 AMG
I have the same issue and I have replaced both sensors. Any body get this issue resolved so far ?
Old 10-27-2018, 10:01 AM
jrneubauer's Avatar
2006 E320 CDI & 2016 Toyota 4Runner
I'm a three Mercedes family and I'm kind of ashamed to tell you what I did. My Wife kept getting a Low Washer Fluid warning come on her 2011 C300 and could never be cleared by adding more fluid. After reading about the sensor problem, I decide to add a cup of White Vinegar to the washer fluid reservoir. It's been used to clean windows for many years and it adds some covalent electrons to the fluid mix. The Alarm didn't go away immediately, but I told her to keep using the washers every time that she went out driving. After about a week, she told me that she no longer had the alarm warning to add more fluid. We have run the tank dry and then filled it with blue colored winter washer fluid and haven't seen the alarm since.
Now here's the deal, - I'm not telling ANYONE to do this to their mercedes. I'm simply telling you that it's what I did!!
John Neubauer
Old 08-19-2019, 03:07 PM
Rodzy8's Avatar
CLS 500
Hello everybody,
seems like I have the same problem on my 2007 CLS 500 (219.372). Multiple times a day I get a false alarm and notification about coolant level being too low and also windshield washer level being too low. I checked both sensor and they work fine. Vinegar won't help in this case, because washer sensor works on a float principle.
Did anyone have the same problem and how you solved it? Which SAM unit is responsible for this two sensors? Is there a wiring diagram available online?
Thanks for help.
Old 08-26-2019, 06:11 PM
konigstiger's Avatar
Received 4,415 Likes on 3,145 Posts
'71 Pinto
Wired direct to front SAM (engine compartment).
File Type: pdf
File Type: pdf
File Type: pdf
Old 12-05-2022, 02:10 PM
MarioNikolovski's Avatar
w219
Hello, can you send me wiring diagram from Windshield washer fluid sensor to SAM module? Because i have "Top up washer fluid" message error so i can check wiring if it broken somewere? Thanks
Quick Reply: Windshield Washer fluid level and/or coolant level sensor
