C219 removal of powered front seats **Please Help
06' CLS 500 Pewter/Ash
2006 CLS500 owner here and my front power seats are not moving at all and the seat heat and seat fan are not working either. I want to Fix it myself and I'm assuming it's the motor or module under the seats. Anyone know how to remove the seats? Any tips or links to fixing the seat motor and/or module would help as well. Thanks!
Received 4,415 Likes
'71 Pinto
First step, check main battery voltage in trunk, and auxiliary battery in engine compartment. FYI related fuses: interior fuse panel (driver side dash) f23, f34, f36; rear SAM (left trunk panel) f1, f2.
Thanks Konigstigerfor your reply! Unfortunately I tried all of those fuses you mentioned and even removed them to check the power and condition of the fuses. All working..... I have started to take the bolts off the seats but have not been successful because the drivers side is too far forward to get a socket in the space. Any ideas on what kind of tool to use that can turn the screw with minimal overhead space? Or how to get power to the seats if the computer is broken?
