Sign in using an external account
| Detailing & Automotive Care Use this forum to discuss detailing, cleaning and automotive care to maintain the beauty in your Mercedes-Benz. |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Former Vendor of MBWorld
Drives: NA
2010 Porsche Panamera Turbo Detail
#2 |
Drives: NA
Initial Wash (90 Minutes)
I first begin by cleaning the door jams using a citrus-based cleaner. This helps loosen the dirt and grime in the door jams and seals ![]() ![]() ![]() ![]() Then the engine bay is cleaned using same citrus cleaner. The trick to remember is to run the engine for a while to warm up. Rinse using deionized so there's no water spotting. Use a soft horse-hair bristle to clean components ![]() ![]() ![]() ![]() ![]() Wheels are cleaned using a safe pH balanced wheel cleaner that will not harm the clear coating on the wheels. Various brushes are needed such as horse-hair wheel brush and the EZ Detail brush to get inside the wheels and clean in the wheel well ![]() ![]() ![]() ![]() ![]() The exterior is rinsed, washed using an organic and natural auto soap that is safe for the paint and the environment. My choice for a wash mitt is the GP Australian Sheepskin Mitt. I work in small panels, washing area no larger than where my arms can reach. Once the panel is washed with the mitt, I then rinse the panel washed and rinse the mitt. This way, the paint is flushed from the soap that is holding all the dirt and my mitt is always clean when dipped back into my soap bucket ![]() ![]() ![]() ![]() The paint is dried using our GP MicroDry Towels. These are high-quality foam-core microfiber towels that do an excellent job of drying. Two towels is enough to dry the whole car. I then blow-dry the exterior to get all the water out of the nook-and-crannies using an Airmax Filtered Blower
#3 |
Drives: NA
Paint cleaned and decontaminated (20 Minutes)
Now that paint is washed and dried, it's time to decontaminate and deep clean the paint to prep for polishing. This wasn't all that bad as you can see not much contaminants were picked up by the clay. A very mild clay was used ![]() Paint is polished to remove imperfections and prep for wax (180 Minutes) As I mentioned, I ended up doing a one-stage polish using Menzerna Super Intensive Polish and GP CCS White polishing pad using a FLEX at setting 5.5. The results were stunning considering a one stage process. The panels were wiped with alcohol to assure proper correction ![]() ![]() ![]() ![]() Polishing is complete. You can see how the polish is broken down and has a slight haze that can almost be seen through ![]() ![]() Final polishing results prior to waxing ![]() ![]() ![]() ![]() ![]() Exterior is waxed using a carnauba wax (20 Minutes) Final attention is addressed to tires, wheel well, and wheels (30 Minutes) Door jams are waxed, engine bay is wiped down and conditioned, any rubber trim is cleaned and conditioned (30 Minutes) Glass is cleaned and Final Inspection is done (15 Minutes) Interior is vacuumed, leather is cleaned using Organic Natural Leather Cleaner. All interior panels were then conditioned using a spray that applies a UV coating to protect against sun. We will condition the interior in a few weeks with the proper leather and vinyl conditioner. (50 Minutes) |
#4 |
Drives: NA
Final Results
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Slight haze you may see is from the wax. I had to apply the wax on the hood in direct sunlight and since I used a carnauba wax, it has a lower melting point than the paint temp at time of application. No matter what you do, the wiping will leave a slight haze until the paint is cooled down and wiped ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#5 |
Drives: NA
Thanks to the client, will remain anonymous, and the boys at BBI, Betim and Joey. You guys were great to hang out with and your facility and dedication is second to none. I appreciate you accommodating me and making me feel at home. Glad we had a chance to finally meet and I look forward to many more details at your facility.
#6 |
Drives: E39 M5...sold!
Awesome job!
#7 |
Drives: NA
#8 |
Drives: Kinda...
Damn, just damn. They don't do detailing like that at my car wash. Awesome job, you put me in the mood to spend a full day Zaino-ing my new 550...
__________________
![]() 2012 BMW 650 Cabriolet, titanium silver, vermilion red, M sport, and pretty much everything else... 2012 BMW 750IL X drive imperial blue/oyster, all the toys... 2010 Escalade ESV Platinum, Diamond white, nuff said... |
#9 | |
Drives: NA
Quote:
Good exercise, immediate gratification, and excellent therapy.
#10 | |
Drives: W204 Sold, 997 4S pano
Quote:
Looks great, White has so much orange peel Zaino-ing your new 550 is a waste of time. You need to have that thing wet sanded and 2 stage power polish. I did this and wow - looks fantastic. |
#11 |
Drives: NA
Just make sure whomever is doing the wetsanding specializes in it. Most paints today are very thin as is. Mercedes is on the thicker side, however, it doesn't take much removal of clear to compromise the integrity and UV protection of the clear coat. But nothing beats a finish that is void of orange peel and reflects light perfectly.
#12 |
Drives: W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Moe did my Porsche GT3 and M3..Mo kicks ***
__________________
![]() EuroTeck CF Lip,Matte CF Diff, Trunk Spoiler w/ 19" ET-Murder-1 Wheels, RENNtech LM-V2, V1 Radar, Falken FK-452's, Green Filters, Res Delete, AMGPedals MBWGCM #94! |
#13 |
Drives: NA
| Tags |
| 33, 930, california, detailing, engine, forum, forums, glistening, menzerna, numbers, panamera, perfection, porsche, turbo, uae, white |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
