Sign in using an external account
| Diesel Forum Forum for Diesel engine vehicle related discussion |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#26 |
Drives: C200cdi
#27 | |
Drives: Chrysler 300C CRD srt
Quote:
We are using CP3 from 400CDI & 1800 bar, if this isn't big enough I'll go for CP3 from a duramax the length of the manifold is 108 mm for the middle cilinder, 117 outside. It's him who gave ideas for the exhaust. Thanks for the help |
#28 |
#29 |
Drives: C200cdi
Yes, but it is only my opinion. This is yours project - you do as you like, do not listen to me too much. I wish you all the luck. |
#30 |
#31 |
#32 |
#33 |
#34 |
#35 |
#36 |
Drives: 2005 E320 CDI
That is just beautiful!!!
__________________
![]() 2005 E320 CDI 2011 BMW X5 35d |
#37 |
#38 |
have some nice info on cdi injectors
1350bar Standard OM 613 injectors tested at 1600bar: 2000 injections 1100 ms = 117gr With AMG nozzle at 1600 bar: 2000 injections 1100 ms = 204gr
#39 |
#40 |
#41 | |
Drives: C200cdi
Quote:
They won´t be enough to 1600bar. With 1,5ms/1350bar, orig injectors gives ~90mm3 and AMG,s ~110mm^3, measured by Robert Boch co. And Bosio power+ nozzle with real AMG body ~120mm^3. To 1000nm torq you need ~155mm^3 to max torq area and for 400hp at least ~125mm^3 to max power area /4200rpm). Boost between 2,3-2,5bar. I have now measured 800nm/350hp with single Holset 35, propably more, but transmission do not stand that and slips uncontrolled. |
#42 |
#43 |
I need some pop-corn!
![]() This is the best thread on MBworld! Congratulations on the brave effort to get more power out from your MB diesel engine, not a lot of people doing that!!! |
#44 |
Drives: CLK 270CDi
#45 | |
Drives: 2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI
Quote:
#46 |
An offtopic question:
How do you guys read/see the injection quantity? I have a ELM interface but the injection PID it's not available! In DAS it's possible to do some logs or something like that? Thanks |
#47 |
Don't know what you mean exactly but the injectors have their own map.
#48 | |
Quote:
I do some logs to fine tuning the maps and etc. with a ELM327 interface and PCMSCAN software, but in my OM642 ECU the "PID" for injection quantity is not read by the ELM327, but other like Lambda, Map, Maf, Exaust temp, etc are all there! |
#49 | |
Quote:
I'll ask my computer guy, I am more hardware
#50 | |
Quote:
After changing injection time and cycle for example, if a measure could be done it's a good thing Any alternative to the ELM327 interface? Where in Star DAS we can do some logs or check the real values? (DAS and real values have some lag!) With Vagcom on TDI engines we can do a lot of logs and check all the parameters... |
| Tags |
| 300c, benz, cdi, chrysler, desktop, diesel, e320, ecu, gtb2260vklr, mb, mercedes, om642, stand, standalone, swap, turbo, twin |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
