Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > Diesel Forum
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-28-2012, 04:40 PM   #1
Drives: e300 diesel
Won't start
I've got a '97 E300D, 6 cylinder 3.0 liter diesel mercedes. It was running fine but won't run now. i changed the battery, and the engine turns over just fine. Put some fuel in the tank just to be sure.
I'm thinking it could be a clogged fuel filter, since I bought the car used and have no idea how well it was maintained.
Any other troubleshooting ideas?
To remove this ad, register today or login if you already are registered!
arturo71 is offline   Reply With Quote
Old 04-29-2012, 09:38 PM   #2
Drives: 1997 E300D
Try a spare key. This car has a chip in the key that can fail, allowing the engine to crank but not fire. This car also can have an air leak into the fuel lines, and if parked on a hill nose up, the fuel runs back to the tank, making it hard to start.
nelbur is offline   Reply With Quote
Old 04-30-2012, 01:11 PM   #3
Drives: e300 diesel
Aha, that makes sense...I did have the car parked on an incline in my driveway, nose up...most likely air in the fuel line, then.
So, how to remedy that?
Old 04-30-2012, 03:02 PM   #4
Drives: 1999 E300TD
If you don't want to look for the leak, then just have a spare battery available and crank and crank and crank until the air is purged!
Alternatively, have a neighborhood push party and reverse the direction of the car on the incline so the nose is facing downward!!
Hopefully by morning all the guests and beer bottles are off the lawn and the car will start.
Plutoe is offline   Reply With Quote
Old 04-30-2012, 03:24 PM   #5
Drives: 1997 E300D
There are quite a few places that air can get into the fuel line up near the engine. If you had fuel related work done recently, like a fuel filter change, that would be the first area to check, but there are numerous O-rings on the clear fuel lines that could leak air. Unfortunately this engine is not equipped with a manual fuel pump, like earlier engines were. If you can roll it to where it is level, or better yet, so the nose is lower, you should be able to crank it enough with the starter to prime the system. Do not just crank it continuously, as you will kill the starter. I would crank it for 10 to 15 seconds, and walk away for 10 minutes for the starter to cool. Then repeat, until it starts. If you fill it up and park with the nose down, the place where the air was getting in will likely leak fuel, which might eliminate a lot of trial and error.
The reason I know this car has this problem is because my neighbor owned my car and parked it on a sloping driveway. I watched a roll back from a local shop pick up the car three times in a weeks time. After it disappeared for the third time, I asked him if he didn't want to sell it to me so he could get something reliable. When it came back he said they found an air leak, but he didn't know exactly what had leaked air. He had a newer Mercedes about a week later.
Old 05-10-2012, 01:03 AM   #6
Drives: e300 diesel
thanks for the tip. I've seen a lot of videos on YouTube with older models that have the hand primer pump you are talking about. too bad mine doesen't have one!
Will keep trying.
thanks.
Tags
car, cdi, clog, cranks, diesel, e300, fuel, hills, incline, line, mercedes, parked, start, suv, wont
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
