DPF monitoring tools - anyone
What does the owners manual say about the notice.
Are you supposed to do anything differently?
Typically you don't show anything on the instrument panel if it is not "actionable", and I wonder is the warning so you know what is happening in case you feel it driving differently, or if there is some thing you are not supposed to do.
(I can't imagine you are supposed to drive past your destination just because it is in regen?)
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
Seems on line there are a lot of people commenting on the diesels with DPF lights and messages.
I wonder how MB has made it seamless for two generations of engines now?
Are we just blissfully unaware, or do our diesels really require less attention to DPF regen cycles?
I really cannot believe there is anything unique about MB regeneration techniques. A succesful regen will require > 600F and about 15 mins (continously) to effectively rid of soot on the DPF. For those who drive less than 10 miles daily - I do not understand how an effective regen will ever occur. So much so in winter. Some companies even require that you maintain >2000 rpm during the entire time.
Here is a
of how hot it can get during regen.
Here is a
I would agree about the time needed. Just surprised there is no notification system in our cars, and considering the number of MBs that are grocery getters, we don't see a rash of failed/plugged DPFs.
I do my best to avoid short trips in the GL since my goal is another 100K miles.
Although knowing I can get it cleaned for about $500 has taken some of the concern away.
#33
#34
Regrettably I could not find any cross reference to OBD codes P1536\1538 within the MB light transporter with your VIN(Sprinter)
In my opinion that typically means that the scannar is NWAS!! I believe you do not have many options!!
If me I would go to specific Sprinter forums for help
#36
Most scannars that I am famuliar will provide a fault number,but also provide some short generic fault description and although the fault code number may be different between scan mfgs and the car manufacturer, the description is typically the same.
On the Sprinter their are about seven MB DPF faults with varing descriptions, therefore to determing the corresponding fault what are the Maxidiag fault code descriptions????
#37
W211 e320 CDI
Btw, I'm pretty sure smaller motors which run in normal operation under higher loads, as in increased chamber pressure, boost pressure and EGT's, will require much less frequent regen cycles to keep a DPF clean. Giant 6-8 liter truck motors run around at idle power so can clog up DPF much more easily. Just a thought, happy to be proven wrong.
#38
I do not want to start the fire about additives pluses and minuses, but after I pull my intake yesterday to replace it (thinking that is badly clogged up around the flaps) just to find very small build up (may be 1 mm on each side) on them I am willing to say that they do more good than bad. Car has 105000 miles and I have been using DT 2000 for last 60000.
#39
Just had DPD cleaned for $609.88. in Melbourne Florida.
2008 E320, 175K miles, Florida only use, 20% hghiway 80% city
Sure runs great afterward.
Rob's Euro Werks 321-255-4555
Vincecam (08-31-2022)
#40
Funny watching these old threads get revived from time to time.
VW TDI will continue to run the radiator fans and smell like burning when the engine is turned off during a regen cycle. I saw the DPF warning light once or twice when I was making frequent short trips, so I changed my driving habits a bit. Finding reasons to go 130mph on the autobahn (when I lived in Germany) and I never saw the light again.
Our GL350 Bluetec is mostly a grocery getter and kids to school vehicle so I have to find excuses to take the keys from my wife and get it on the Highway regularly if she doesn’t.
IBelieve (08-29-2022)
#41
Received 1,729 Likes
1922 Ford Model T / no OBD
I doubt 130 mph does big difference to DPF regeneration.
I drive my Sprinter with ScanGauge all the time and regeneration is pending even when I coast downhill for 5-7 miles. So ECU is not giving fuel for power stroke, but is giving fuel on downstroke to push burning fuel down to DPF.
DPF temperature drops only slightly when engine is not pulling, but gets pulled.
#42
#43
It happen before that DW aborted the regeneration coming home.
Following day I drove the car observing ScanGauge and regeneration resumed once the coolant reached 60C.
So engine was barely warm, yet computer continued with regeneration.
That was in city driving, where I was stopping at red lights. Than to my disbelieve, the computer would still do ECO engine shut downs with pending regeneration.
#44
Not per my experience again.
#46
Meaning using sedan for city driving, I usually have end of the trip in just few miles.
Would the regeneration start at the beginning of longer trip, I would not worry about couple of ECO stops during regeneration.
#47
I do the same, but having trust in German engineering, I believe this is overdoing it.
