No More ESP 5w40
Old 04-11-2015, 03:00 AM
element913's Avatar
2005 E320 CDI
I had trouble finding the ESP Formula M 5w-40, so I switched to Pentosin HP2 5w-40 as it is listed with MB-Approval for 229.51. When I bought it, it was $37 per 5 Liters at RMEuropean, looks like its $43 for the same jug at Amazon.
Amazon.com: Pentosin (5W-40-HP2-5L) SAE 5W-40 Motor Oil - 5 Liter: Automotive Amazon.com: Pentosin (5W-40-HP2-5L) SAE 5W-40 Motor Oil - 5 Liter: Automotive
Old 04-15-2015, 05:37 AM
vaccin's Avatar
05 cdi 3.2 92 300d 2.5
How many miles/km's for OCI
If were talking premium oils OCI is valid
Old 04-26-2015, 02:04 PM
greasykid's Avatar
2015, ML250 BlueTEC
Recently bought new spec Mobil 1 0w30 from O'Rilley Auto Parts for $5.99/qt. They special ordered it from their warehouse stock.
Old 04-29-2015, 06:59 PM
B Marques's Avatar
2010 C300 4Matic, 2011 GL450, 2005 ML500, 2010 GL350 and 2003 SLK230
Anyone use Rotella T6 Full synthetic?
Old 04-29-2015, 08:43 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
It is not MB rated for DPF vehicles.
Neither is Delvac 1 ESP (even with the ESP designation)
Old 04-30-2015, 10:12 PM
B Marques's Avatar
So what should we use if we can't get the original anymore?
Old 04-30-2015, 10:39 PM
  #32
Super Moderator
samaritrey's Avatar
THE C350
Mobile 1 5w-30 esp or 0w-30 esp Both meet 229.51 approvals
I currently am using 0w-30 esp and so far seems fine
Old 05-03-2015, 09:19 PM
  #33
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
I use T6 in my ML, but Mobil 1 in my CDI. T6 got rid of peanut butter.
Old 05-08-2015, 11:38 PM
  #34
B Marques's Avatar
Local Walmart/Autozone/Advance didn't have any ESP mobile 1. Does anyone recommend another place to get it at a fair price? Amazon/eBay seems a little high.
Old 05-09-2015, 12:01 PM
  #35
greasykid's Avatar
2015, ML250 BlueTEC
Where to get Mobil 1
Recommend reading previous posts here.
Old 05-10-2015, 12:59 PM
  #36
Super Moderator
samaritrey's Avatar
THE C350
Did you try Napa? Even if Napa doesn't have it they should be able to order it for you.
You could also go to mobile 1's site they use to have a store locator and then just call all of them.
Old 05-20-2015, 06:16 PM
  #37
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I went to the dealership today and the specified oil for an 06 E320 CDI is Mobil 1 ESP 0w30. The part number is Q1090182 is the new number that superseded the Mobil 1 ESP 5w40 viscosity. Paid $6.95/Quart, list is $10.50. I too was questioning the parts manager but he double checked and reassured me this is the new oil.
Oil filter part number is 613-180-00-09 paid $9.60, list is $12.00
Old 05-25-2015, 06:51 PM
  #38
skw
skw's Avatar
2019 GLS450
Originally Posted by 06e320cdi
It appears that MB has changed the oil spec and discontinued the use of Mobil1 ESP 5w40. What they are putting in now is MB branded 5w30. I am unable to find out from anyone why the change. The MB branded bottle does not even specify ESP, it just has a green cap. I went to Napa, they were out of it as well, and no longer shows in the Mobil book. I ended up purchasing the Mobil 1 ESP 5w30. Not sure I like the lighter weight. I did pass a stack of LubiMoly 5w40 that lists meeting the 229.51 spec. Any thoughts.
I'll pre-face by saying that I have the om642, not sure if we're all talking about the same engine and how much of a difference it make as to if all the diesels were to take 229.51 spec oil. From the bit of research that I've done, I found a few sources that stated the Mobil 1 ESP 5w-40 is being discontinued. The MB branded bottles is rumored to be Mobil 1 ESP 5w-30. The MB packaged bottles have a green cap and says spec 229.52. I found 2 train of thoughts for the new spec. 1 was that it is to try to address some of the oil leak issues from over the past few years. 2nd was that it is to improve emissions/fuel economy.
I've tried a few oils and haven't noticed any change in performance or fuel economy. Spec 229.51 has 0w-30, 0w-40, 5w-30, & 5w-40 oils. Spec 229.52 is only 0w-30 & 5w-30. I'm under the assumption that my ML came factory filled w/ Mobil 1 ESP 5w-40, which probably also had another additive pkg for break-in. My 1st oil change I used the Amsoil 5w-40. Next one I forgot to order in time for when I planned to do the oil change so I picked up Mobil 1 5w-40 from the dealer when I went to get a filter. For the 3rd change I had happened to be at my BMW dealer and found that they carried the Castrol Professional OE 5w-30 for their diesels. The Castrol carries both BMW LL-04 and MB 229.51 approval and was just under $6/qt w/ my BMWCCA discount. This last oil change is when I found BMW and MB both switched to their own packaged bottles. BMW's repackaged oil for the diesels is a Shell 5w-30 LL-04 oil but I couldn't find exactly which one There's 4 Shell oils that meet their spec and 1 Pennzoil that meets BMW & MB specs. As I mentioned above, I was told MB's repackaged oil is Mobil 1 ESP 5w-30. However, my local Advance Auto Parts store had Valvoline SynPower MST 5w-40 on sale for $5.59/qt which has the MB 229.51 approval so I used that this time around.
For reference:
229.51 https://bevo.mercedes-benz.com/bevol...229.51_en.html
229.52 https://bevo.mercedes-benz.com/bevol...229.52_en.html
Old 05-25-2015, 06:54 PM
  #39
skw
skw's Avatar
2019 GLS450
Mercedes-Benz 229.3, 229.5
Fail!
AMSOIL European Car Formula 5W40 is indeed on the MB list of 229.51 approved oils. https://bevo.mercedes-benz.com/bevol...229.51_en.html
Old 05-25-2015, 11:36 PM
  #40
N_Jay's Avatar
Looks like AmsOil decided to up there specs.
Old 05-26-2015, 12:01 AM
  #41
skw
skw's Avatar
2019 GLS450
Amsoil had the MB spec on their bottle label back when I was using it 2-3yrs ago in all my cars, hence why I also used it in the MB. I can't comment if it was also on the MB spec sheet as I can't remember. Due to the number of people that seem surprised to see it on the sheet, I'm inclined to believe that it was not.
Old 05-26-2015, 08:18 AM
  #42
N_Jay's Avatar
Do you use red label or black label?
Old 05-28-2015, 07:53 PM
  #43
Super Moderator
samaritrey's Avatar
THE C350
I am in the surprised camp as well that Amsoil is actually on the list now as I know they claimed it met the specs but never paid to get it tested and actually approved.
I never liked them because some of the sales guys were flat out lying to people but now that they manned up if I can get a good price I would try it.
I am currently trying out the 0w-30.
Old 05-28-2015, 09:12 PM
  #44
N_Jay's Avatar
They have two different oils. One is 229.5 and the other is 229.51
Old 09-14-2015, 05:28 PM
  #45
krd2023's Avatar
formerly drove a 2010 ML350 BLUETEC, currently drive Mazda, Chevrolet, and Toyota
While we're on the "oil specs" topic, you all may be interested in data and insight posted this week from Ausmbtech in my thread as found here: https://mbworld.org/forums/diesel-fo...-seized-3.html
The OM642 engine in my 2010 ML350 Bluetec seized in April this year @ 82K miles after all regular dealer maintenance. The dealer used MB Part # Q1090143 MOBILE 1 ESP FORMULA MB 5W40 at each and every oil change service, as noted on all of my dealer service invoices. It's becoming more clear to me why 5W40 oil is not to be used in the OM642 and other diesels.
Old 09-17-2015, 08:17 PM
  #46
pdisher's Avatar
2011 E350BT
Exclamation
Mercedes Benz changed the oil spec and notified the dealer network. They did not make much of an effort to notify the customer.
I would research and carefully before selecting an oil.
229.52 appears to be the only way forward based on the documentation I've researched.
Old 09-17-2015, 10:01 PM
  #47
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
My preferred oil for current MB diesels is the new Mobil 1 ESP X1 0w30. It has 229.31, 229.51 and 229.52 approvals so it's easier to have one oil for a range of vehicles.
Non-DPF 646, 647, 611, 612, 613's and earlier engines I still use Regular Mobil 1 0w40 which is a 229.5 oil
Quick Reply: No More ESP 5w40
