W211 and W212 diesel reliability and maintenance costs?
First off, apologies for the wall of text. I'm new here, and I figured you might have more in-depth advice and experience than I would get elsewhere. I'm currently carless and looking at my potential next car. I've never owned a Benz before, but the ultra-high MPG numbers on the diesels, coupled with plenty of torque, make the last 2 generations of E class diesel very appealing to me. However, I would need a car that I can trust not to break down when I need it, and that I can prevent expensive repairs by spending a reasonable amount on preventive maintenance. I don't know very much about cars, but I would like to learn to work on whatever car I get so I can avoid the most expensive labor charges. With that in mind, I have a few questions:
- Which generation is easier to work on yourself, if at all possible: I6 E320, V6 E320, or V6 E350?
- Are there any specific problems to watch out for on a used model? I know a similar car in this segment, the BMW 335d, is known for having carbon build up issues.
- How much should my annual repairs/maintenance budget be on any of these cars? How much cash should I have in reserves before I start looking at a Benz?
We haven't had any of the carbon buildup issues, but some higher mileage cars have needed their DPFs replaced or cleaned. There's also an issue with some oil leaking into the turbo on the V6
Annual maintenance? It's a used German car, so it'll be more than an accord but not as bad as many people on message boards claim. If you get an I6 W211, be sure to avoid the ABC suspension as it's expensive to repair. It was not offered on an US-Spec OM642 V6 Diesel E-Class.
Thanks for the advice. I'm currently looking at a 2008 W211 E320 Bluetec with the V6, since the emissions are supposed to be a lot cleaner than the previous CDI model. The dealership is asking $20K with about 50K miles, so it's above KBB but not too outrageous. If they still have it when I have the budget to afford it, I think I'll go for it. Otherwise, there's a 2005 CDI model for half as much, but with about 130K on the odo.
Cars are always a little more expensive at the dealer, but you expect a higher quality product. Get a firm commitment about what types of repairs they will cover within a specific time period and mileage. You can itemize this in the sale agreement.
Maintenance won't break the bank so long as you don't take it to the dealer. But if you do take it to the dealer, expect to pay $500 - $1000 every time.
BTW, the fact that the diesel forums seem to have very little chatter suggests to me that they generally run fairly problem free.
Or you could go a little older and with the money you save, buy a really awesome aftermarket unit.
To replace the MOST system, you have to basically rewire the entire car and replace the amplifiers located under the rear seat. In addition, you will likely lose any steering wheel and instrument cluster integration.
So yes, if you want to get a 2007 and spend 5-8K on rebuilding the car's communication systems, sure go ahead.
Mine is a 2013 C250.
Besides tires and service A & B, only had to change the front mounts. My local indy MB shop charged me $500.00.
I'm pretty happy with it so far after 60k diven.
SLK55 AMG, E320 BlueTec, ML350, (formerly) C32 AMG, MR2 Turbo, HD-FLH-FSE, BMW R100RS, Ducati M900
E Klasse oil burners
All I would add is that I am highly satisfied with my E320 BlueTec. I have a very competent and reasonably priced MB Dealer nearby and one really good independent shop to provide maintenance. My 14 yr experience with MB has been 99% positive and for me the Benz (mostly AMG's) were trouble free and very economical to operate, aged well and looked and ran like new cars for many years. They rarely break and most systems were rebuildable. It does seem to me that the older cars were better designed, better built and possessed fewer serious flaws. Not flawless but just overall better. But their more simple systems and fewer emissions driven add-ons helped. Things like water cooled transmission coolers that leak coolant into the transmission or SBC braking that have failure modes that could lead to No Brakes have become more frequent. This distresses me because I like MB and would like to keep at least one in my driveway if I can. I drive my cars hard and aways figured that any car designed to run on the German Autobahn would have better brakes, better cooling and in general hold up better to my abuse which is nothing compared to running on the Autobahn. Look at the disc brakes on most other cars. Look at the engine oil capacity. The radiators, etc. Most of the MB's are good cars. But some have big flaws. I would love to own a 2003-2006 SL500 or SL55 but after learning about SBC, I want nothing to do with any car possessing such a flawed system. I wish we did not need to ferret out that info ourselves too. I wish MB would design a permanent repair or retrofit for those older cars but they seem intent of letting their owners fend for themselves. Let the buyer beware.
Irish
The following 2 users liked this post by JG26_Irish:
MykhailoM (12-27-2022),
StradaRedlands (07-10-2018)
Received 1,730 Likes
1922 Ford Model T / no OBD
When there is more I6 v/s V6 diesels to compare, I am more and more impressed with my I4.
Haven't pushed it to governor kick yet, but I see engine making 150 mph easy.
Last week we took 560 miles trip to CA and then back. I was keeping CC at 85 mph, but did not mind to go faster if I had "radar volunteer" in front of me.
For some distance I was following Charger. The guy was pushing the pedal to the metal on passing and I could hear each transmission downshift, sometimes double downshifting when Charger was struggling to accelerate.
My 4-banger, while keeping some distance was easy following without dropping from 7th gear
Still making 40 mpg.
