Where is my block heater?
Old 01-09-2017, 11:17 PM
Shizzell's Avatar
2008 ML 320 CDI
Hi,
I bought the zero start 38 mm threaded coolant heater referenced in this thread, but it turns out my vehicle doesn't have the threaded fitting. After reading up further, it looks like only northern vehicles received them. Is this the right part number for the new fitting? 6422000256 (om642)
I'm assuming this has the 38mm threads I can screw my zero start heater in. Any guidance here would be appreciated. I'm pretty sure, I just don't want to dive into 150$ in this part with coolant without a bit more confidence.
Old 07-17-2020, 09:08 PM
Lmed's Avatar
2015 GLK 250 Blutech
Hello.
where can I find the External 120 volts plug i have the original plug but no external plug. I bought the vehicle use.
any help would be greatly appreciated.
Thank you..
Old 07-18-2020, 04:53 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
Originally Posted by Lmed
Hello.
Thank you..
Is it DEFA system? Go their webpage and then check ebay for part you need.
Old 07-19-2020, 04:00 PM
Lmed's Avatar
Thank you I will check it out on Monday.
Rgds
Old 07-19-2020, 05:52 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
There is a block heater in the Mercedes part system. I wouldn’t mess with dime store solutions.
Old 07-20-2020, 03:14 AM
mersum1es's Avatar
We are talking engine pre-heater, which is AC powered. True, sometimes these systems are messing slightly with cold start fratures of car, but on the other hand you have always warm angine and warm cabin when you start the car at -30C. Huge advance in comfort and lubrication of the engine.
Old 08-13-2021, 03:55 PM
  #32
prabhakarglv's Avatar
2020 Mercedes Benz Sprinter 3L V6 Turbo
Hi, I'm from the province of Alberta and new to this forum. Recently I bought a Motorhome with 2020 Mercedes Benz Sprinter 3.0L V6 Turbo Chassis (Model: XCC1706). This unit didn't come up with Block Heater. When I called MB Calgary Dealer, they said I can install DEFA Miniplug. I ordered the part.
Where exactly the location of this cap when I'm watching under the front portion of engine?
Does DEFA Miniplug one end fits to that spot?
Thanks in advance for your help.
VEN.
Quick Reply: Where is my block heater?
