'82 300D coolant leak help
Old 07-27-2016, 10:06 PM
jfontana's Avatar
2022 GLE 450, 2003 SL500
I recently purchased a '82 300D with 155K miles. I drove it home about 250 miles successfully only to discover oil and coolant on the garage floor. I'm reasonably sure the oil is from the cooler lines, however not sure on the coolant leak. I am told by an independent garage that the coolant line comes from the A/C ? Can anyone explain and possibly offer me a part # or at least a description of the part and best place to buy it?
Old 07-27-2016, 11:06 PM
kajtek1's Avatar
Received 1,728 Likes on 1,378 Posts
1922 Ford Model T / no OBD
Congratulation on classic purchase.
As you experienced, classics don't come without additional charges and from my memory those engines have about 20 weak oil points that can leak and most likely will leak more or less. Wash the engine often and keep observing. Once you narrow the area, stuff paper towels there for pinpointing.
If you are beginner, take pictures and post here and we will help.
For starters check all the fluids for cross-contamination.
Old 07-28-2016, 09:20 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Post your VIN!!
Old 07-28-2016, 09:41 AM
jfontana's Avatar
I don't have my vin handy. Is the vin number crucial to answering the original post?
Old 07-28-2016, 11:10 AM
Plutoe's Avatar
1999 E300TD
No, it only affects the correctness of my answer, however if you are simply looking for loads of HS responses then I am not a source!!
Old 07-28-2016, 11:15 AM
kajtek1's Avatar
Beware of unqualified "mechanics" who will not find a machine bolt without VIN.
There is no use for VIN till you narrow what problem you have and are ready to order parts.
Old 07-28-2016, 12:15 PM
jfontana's Avatar
I have a 1982 300 Turbo Diesel that is leaking antifreeze on a driver's side line that comes from the A/C. How many of these lines can there be? I am not looking to make it difficult or ... garner tons of responses. I've also encountered 'historians' on other classic car forums that just want vin numbers for their personal collection. There's a Corvette guy that ends up selling to others what he gathers. Just thought somebody here could help out, not make a project out of it!
Old 07-28-2016, 12:31 PM
kajtek1's Avatar
Again a picture would give you much more precise answer.
There is no coolant in AC. I think what you describe is leak on heater loop.
You can bypass whole heater for the summer and take care about more important things, while coming back to fixing heater for the winter.
1982 are no longer supported, but here is drawing of heater parts for 1984
http://www.mbdirectparts.com/mercede...part_name=core
jfontana (07-28-2016)
Old 07-28-2016, 01:23 PM
jfontana's Avatar
Thank you for the attachment! I knew there was no coolant in the A/C but noticed the leak was around the A/C and wondered if the coolant was some how designed to cool externally the A/C operation. I can't get a pic until next week as I need to get the car on a lift then. If I can't figure it out, I'll post a pic of the problem at that time.
Quick Reply: '82 300D coolant leak help
