W211 E270 cdi oil leak infront of Turbo Charger
Old 10-08-2016, 08:24 AM
Azeem's Avatar
W211 E270 cdi 2004
My diesel e270 cdi has oil sump at turbo charger. Please see attached picture for oil leak (second pic was zoomed in for clarity to see where the oil leak is).
Can you please guide me if a seal is leak and what is the part number?
Attached Thumbnails W211 E270 cdi oil leak infront of Turbo Charger-img_1024.jpg   W211 E270 cdi oil leak infront of Turbo Charger-img_1025.jpg
Old 10-08-2016, 09:10 AM
marc hanna's Avatar
2008 R320 CDI, 1987 560SL
That's the crank case breather inlet. Sorry, I couldn't find your exact year and model, but this should be the same:
Old 10-08-2016, 09:26 AM
Azeem's Avatar
W211 E270 cdi 2004
Thanks. Its OM647 R5. Do you reckon it's same as E320?
Old 10-08-2016, 09:27 AM
Azeem's Avatar
W211 E270 cdi 2004
By the way its 2003 model E270CDI. So if i were to order the part, its Ring for inlet breather pipe?
Old 10-08-2016, 09:36 AM
marc hanna's Avatar
I see, yours is the in-line 5, and the E320 in an in-line 6. It's very possible it will fit but not certain. Try taking it apart first and cleaning it. This is not indicative of a serious problem - you may just be able to put some sealant on it to correct the problem.
Old 10-08-2016, 10:22 AM
Azeem's Avatar
W211 E270 cdi 2004
Thanks Marc.
Old 10-08-2016, 11:58 AM
marc hanna's Avatar
No problem. Just so you're aware, the function of the breather is to direct engine oil vapours and residue into the intake, so it's normal and expected to see a certain quantity of oil in there.
Old 10-08-2016, 10:04 PM
Azeem's Avatar
W211 E270 cdi 2004
Thanks. In that case, i'll leave it as it is.
Quick Reply: W211 E270 cdi oil leak infront of Turbo Charger
