Torque for vacuum pump bolts
Old 02-10-2017, 09:26 PM
Bigben97's Avatar
2012 GL350, 2010 A4, 2007 911TT
I have an oil leak that I was told the vacuum pump, 6422300165. Visual confirmation seems to make sense that's where it's coming from. i have the part but need to know how tight to torque the bolts holding it on. Can anyone provide this or a place to find it?
This is on my 2012 GL350.
Old 02-11-2017, 09:50 AM
Bigben97's Avatar
Picture of the box.
Old 02-13-2017, 02:32 PM
sak335's Avatar
2012 GL 350
I just removed that from my 2012 the other day. I'll dig up the spec tonight and post it for you.
Old 02-13-2017, 07:35 PM
sak335's Avatar
2012 GL 350
All bolts: 9 Nm
Old 02-13-2017, 07:52 PM
ItalianJoe1's Avatar
2003 CL 600
Just an FYI, you can get just the sealing ring for that pump, if it's leaking from there, which most are.
Old 02-13-2017, 10:19 PM
Bigben97's Avatar
Cleaned everything up and it seems to be resolved except a slight leak at the hard piping on the top/front of the engine where the hard pipes come together. Need to figure out if I'm missing a piece or o-ring or if it's just in need of a new o-ring.
I did a new gasket at the oil filter housing. That seems to have solved it but everyone I talked to said it was most likely the diaphragm inside the vacuum pump. Should have tried the gasket first, oh well.
Bigben97's Avatar
Originally Posted by sak335
All bolts: 9 Nm
Thank you by the way.
Quick Reply: Torque for vacuum pump bolts
