Suspension special
Old 08-10-2015, 07:27 PM
  #76
CPatrick's Avatar
'17 AMG C63S Coupe
If you put as much time into your website, as you do bumping this thread, then maybe you wouldn't need to resort to this type of advertising.
Coming soon...
Old 09-03-2015, 11:16 PM
  #77
Former Vendor of MBWorld
FXAutodesign's Avatar
C-class
All PM reply
Old 09-27-2015, 01:55 AM
  #78
C-class
PM reply
Old 10-09-2015, 12:26 AM
  #79
C-class
PM reply
Old 10-16-2015, 02:18 PM
  #80
john1c's Avatar
2012 E350 coupe
Awesome guys!! Definitely recommended!
Old 10-16-2015, 03:39 PM
  #81
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
The original posting below is from 2010. Does this special still apply? I'd suggest creating a brand new thread with current special.
I understand the H&R Spring will work with the E550 Coupe with Dynamic Sport Suspension. From this forum it appears the rear typically drop a bit more than the front. I'm interested in a very mild drop but am looking to have the front drop slightly more than the rear as the front gap between the top of the tire and the fender edge is larger in the front.
Any suggestions?
Originally Posted by FXAutodesign
We're doing special promotion for H&R Spring & Installation Package
for most Mercedes E350 Coupe W207
$449 plus tax
for local customer
More information please feel free to call us at 1-562-547-6955
Old 10-16-2015, 05:30 PM
  #82
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2004 E320 (sold), 2012 E550 coupe (sold), 2017 C63 sedan
Any suggestions?
I was pondering the same...I noticed that the rear springs have a shim at the top, sizes range from 5 - 17mm, close to 0.5 inches in difference. All depends on what your car has on it from the factory... But it could be a potential solution. Item 6 in the diagram below.
Old 10-17-2015, 10:06 AM
  #83
ffr2014's Avatar
Thanks! That does like a possible solution (and an inexpensive one). I'll do some research (let me know if you discover anything viable).
Old 10-17-2015, 11:07 AM
  #84
ffr2014's Avatar
We should probably create a new thread once we have more solid info on potential solution for "adjustable" lowering using H&K lowering springs and the upper coil spring insulator. It looks like a single part number for the rear coil spring upper insulator for E550 Coupe w/ Sport Suspension: MB Part Number 2103250184. I believe the shims/insulator with the variable sizes of 5-17mm are for the E-Sedan and not compatible with our E-Coupes (the e-coupe is actually based on C-class chassis to my understanding).
Can the OP, Next Motorsport, provide any guidance?
Old 11-05-2015, 01:59 PM
  #85
C-class
Thanks for sharing
Old 11-23-2015, 04:24 PM
  #86
C-class
All PM reply
Old 11-23-2015, 05:23 PM
  #87
ffr2014's Avatar
I have not received a PM as of yet. Is there a variable drop option for the MB E550 Coupe with Dynamic suspension? Are the shims shown in the previous posts viable for the E-Coupe (or only for the E-Sedan)? Thanks!
All PM reply
Old 11-24-2015, 11:47 AM
  #88
kellankong's Avatar
MB E350 coupe 2012
hi I'm using the HR spring on my E350, the rear does drop a bit more. So does the front coil have that item 6 too? Is that mean if I want to drop the front more base on HR spring, I can also replace the particular part in the front in order to achieve a 'even' drop?
Old 11-24-2015, 01:29 PM
  #89
ffr2014's Avatar
In theory, yes - using a thinner shim in the front and/or a thicker shim in the rear should even out the drop (assuming the rear drops more with those springs). I have not had any confirmation however on whether those variable size shims actually exist for the E-Coupe. I believe the part numbers and diagram depicted are for the E-Sedan only. Can anyone provide guidance here??
Quick Reply: Suspension special
