What size wheels?
Old 04-11-2011, 08:24 AM
threeMBs's Avatar
Only MBs - the best or nothing
Fitting 20" wheels was never an issue. Finding properly load rated 20" tires (especially for the front) for E coupe (or for E sedan for that matter) with high enough sidewall (to maintane civil enough ride and "protect" wheels) to fit within those fenders (and to clear perch up front) was and still is an issue.
245/35-20 front tire would be ideal, but it does not fit due to that perch.
255/30-20 front tire does, maybe even 235/35-20. But both do not have correct load carrying rating. People, putting anything less (245/30-20, 235/30-20 or 225/35-20) upfront, are playing with fire and have no clue what they're doing.
Old 04-11-2011, 03:19 PM
gavrocool's Avatar
e350 coupe
https://mbworld.org/forums/e-class-c...installed.html
Here are some pictures with both my set ups(winter and summer),but i ordered my self a new set of summer wheels because the old ones won't have clearance in the rear because of the new brakes.So i am selling the old ones.Anyway the set up was 255/30/20 8,5*20 et35 front and 285/25/20 10*20 et42.I had to roll my fenders for the rear.I was having problems only with 4 persons in the car.
Here are my new wheels i ordered.http://www.gmp-italy.com/IT-victoria...ollezione.html
Here's an idea about how it will look my car in about 10 days.http://www.prior-design.de/mercedes_eklassecoupe_c207.These wheels are pretty the same.
Old 04-14-2011, 10:22 AM
efan's Avatar
W177 A250AMG 2019, W212 FL E250 with 63 kit, R8
try to get them to look meaty like Stage's car, check out how his rims fill out the fenders/wings
Attached Thumbnails What size wheels?-neo_img__mg_0434.jpg   What size wheels?-neo_img__mg_0460.jpg
Old 04-15-2011, 02:20 PM
gavrocool's Avatar
e350 coupe
WOW,nice car.They will have the same set up like the old ones.https://mbworld.org/forums/e-class-c...e-my-mods.html
Old 10-19-2014, 03:16 AM
lbegiss's Avatar
E550 coupe , S550 w221, X5m50d, Cayenne GTS
Multispokes c63 on My stock e550
Hello guys.
Ad you know i was looking fon Wheels for a long time...
I finally got the 19 black Multispokes 8j et 45 and 9j et 54.
They are OEM wheels for the C63.
They came with tires 235 and 255.
I'm going to trade in my tires for larger ones:
I was thinking maybe to keep the front tires 235 and have 275 in the back.
If I put 245 in the front . Will I need spacers ?
My car has no modifications. Not lowered and not planning on doing it .
I would like to know the best tire size to handle better.
Thank you so much
Old 06-25-2015, 12:43 PM
MrRadi8's Avatar
E350 Cab
I've got a 2011 A207 that I'd like to lose the stagger on and go with rotatable tires.
I'm thinking just get a set of front or rear 18" AMG 5 spoke and go same size all around.
Should work? Or would I have to change offsets?
Old 06-27-2015, 05:58 AM
  #32
lbegiss's Avatar
Hello guys.
Old 03-20-2016, 01:59 PM
  #33
sundar.sujan12's Avatar
2012 mercedes benz E 350 coupe
20's on c207
I have 20's on my coupe with no issues. I went with 245 30 20 +32 front and 285 25 20 +42 with no rubbing at all. Currently working on lowering it with the eibach pro kit. ill upload a pic.
JBatesE400 (02-24-2022)
Old 02-24-2022, 08:43 AM
  #34
JBatesE400's Avatar
2016 E400 4Matic Coupe
hey brotha,
I'm.curious why the wider 255/20 fits but not the 245/20?
Old 05-03-2022, 02:02 PM
  #35
Arthur Udris's Avatar
c320 cdi w204 2008
Questions about wheel size
Originally Posted by gavrocool
You chose to run with 235 in the front and 275 in the rear but i told you my set up is with 255 in the front and 285 in the rear.It is a big difference and i have to tell that i have lowered my car by 30mm.Take a minute to think about it.IF SOMEONE ELSE WILL LOWER HIS CAR DO TRUST ME FOR MY SET UP.
Hello!
After some research found this topic!
I own c207 e coupe, wondering will C63 alloys will fit on it without rubbering anywhere front 255/35/19 9J et25 and rear 285/30/19 10.5j et57
Regards
Old 05-15-2023, 02:37 PM
  #36
Lv35's Avatar
A207
Anyone running 235/40/19? On C207/A207
Originally Posted by calbear550
chose not to trust you and it worked out. fitted 235/35/20 up front and 275/30/20 in the rear. offset is key, no modding necessary.
what offset are you running?
Quick Reply: What size wheels?
