Sign in using an external account
E-Class Coupe (C207) & Cabrio (A207) 2010-: E250CDI Coupe, E350 Coupe, E350CDI Coupe, E500 Coupe, E550 Coupe [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: C350
Offset Question
__________________
#2 |
Drives: '03 SL500, '10 E350 sdn, '12 E350 sdn
While E coupe does have relatively high offsets, C class (except C63) has even higher offsets.
For the wheels and tires sizes you provided, to get flush firment on an E coupe offsets should be around et35 front and around et50 for rear. But 245/30-20 tire on 8.5" wide et35 wheel and 285/25-20 tire on 10.5" wide et50 wheel will stick out way passed fenders on any non-AMG C-class. As a matter of fact, I'm 100% possitive those tires will rub on C, while they will fit E coupe just fine.
__________________
Current cars: '03 SL500 Sport Slv/Blk on 20" HRE 544R & 20" OZ Opera PL '10 E350 sdn Sport Wht/Blk Pano P1 on 19" '12 E350 sdn Sport Wht/Almnd-Blk Pano P1 on 20" OZ Galileo III & 19" Previous MBs: '10 E550 cpe (will be missed), '09 E350 4matic, '03 E500, '02 ML500, '00 ML320, '00 CLK430, '00 E320 4matic, '99 CLK430 Most significant previous others: '05 Audi A8 (a great automobile) '01 Audi A6 4.2 Sport '97 Toyota Supra '90 Nissan 300ZX '87 Mazda RX-7 |
#3 | |
Drives: C350
Quote:
__________________
#4 |
In order to answer your question, the wheels' offsets are needed to be known. If you'll let me know what they are, I'll be able to tell you what's needed for a flush look on E coupe.
__________________
#5 |
Drives: C350
I just found out that the offsets are et 35 front 8.5" and et 42 rear 10"... Would they fit?
Thanks.
__________________
#6 |
Former Vendor of MBWorld
Drives: N/A
^^Yes !
#7 |
Yes they would (front: flush, rear: flush and then some).
Also FYI: 5mm spacers can not be used on an E coupe. Since hub's lip is only 7-8mm, the 2-3mm left (after installing 5mm spacer) is not enough to properly seat a wheel on (in other words wheel's weight would be supported by bolts instead of the hub's lip). I'm even more surprised than before that these wheels (with such relatively low for C class offsets, as specified) mounted with those wide tires would fit a C class regardless of what was done to fenders. But I'm not expert on C fitments and more to the topic - wheels will fit flush on E coupe.
__________________
Current cars: '03 SL500 Sport Slv/Blk on 20" HRE 544R & 20" OZ Opera PL '10 E350 sdn Sport Wht/Blk Pano P1 on 19" '12 E350 sdn Sport Wht/Almnd-Blk Pano P1 on 20" OZ Galileo III & 19" Previous MBs: '10 E550 cpe (will be missed), '09 E350 4matic, '03 E500, '02 ML500, '00 ML320, '00 CLK430, '00 E320 4matic, '99 CLK430 Most significant previous others: '05 Audi A8 (a great automobile) '01 Audi A6 4.2 Sport '97 Toyota Supra '90 Nissan 300ZX '87 Mazda RX-7 Last edited by threeMBs; 03-28-2012 at 09:05 PM. |
#8 | |
Drives: C350
Quote:
It was a great knowledge about the E coupe. On my C class, I rolled the fenders since it was rubbing with those wide tires at first and I didn't want to switch them again. It will do fine without rubbing if you go 235/35/20 fr and 275/30/20 rear. Me and the one other member on the C forum were the only ones who went with 245s and 285s with no big issue (except for rolling/trimming the fenders) as far as I know. I checked the AMG W204 forum and yes the C and C AMG share the same offsets.Again, thank you so much.
__________________
#9 |
Drives: C350
__________________
#10 |
Drives: e550 coupe
wondering if you guys can help me out with car too! i have an e550 coupe and the wheels im planning to buy are 20 x 9 et36, 20 x 10 et43
can i get them to work?
#11 |
Yes they will fit. Front maybe just a bit too aggressive by a couple of mms, but still will be fine.
__________________
#12 |
Drives: e550 coupe
awesome! thank you
| Tags |
| 2012, 35, 4matic, 550, amg, benz, class, coupe, e350, e550, hre, mercedes, offset, replica, spacers, vi, wheel, wheels |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
