Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > E-Class Coupe (C207) & Cabrio (A207)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-09-2012, 10:49 AM   #1
Drives: 2011 E350 Cab
Cab and AC Vents
Not sure if I can so anything about this.. Other day had the top down in about 75 degree weather (AC off) and was feeling hot air coming thru bottom vents. I cannot find a way to regulate the temp of the air. Is there a way to regulate either shutting that air flow off or regulating the temp?
Mike
To remove this ad, register today or login if you already are registered!
mikey08 is offline   Reply With Quote
Old 07-16-2012, 01:36 PM   #2
So I assume no one has wanted to adjust the temp of the air without AC or heat fan turned on?
Old 07-17-2012, 12:00 PM   #3
BenzMan369's Avatar
Drives: 2012 E350 Coupe.
I've driven my coupe with all the windows down in moderate temps. and the HVAC system off. I did not notice "hot" air at foot level. The air temp. seemed to be roughly the ambient temp. - maybe a bit warmer. But the flow was so gentle, I don't remember it being a problem.
If you're truly getting significantly hotter air through the bottom vents with the system shut down, then perhaps the dealer should take a look. There have been a few reports of hot air blowing from the driver's side vent even when the A/C is operating full blast. So I guess anything is possible.
Other than that, I don't see how the air temp. at the vents could be made lower than the ambient temp. without the A/C compressor's help.
Sorry I can't cure your complaint.
__________________
BenzMan369 is offline   Reply With Quote
Tags
207, ac, air, blows, bottom, cab, conditioner, drivers, heat, hot, side, suburban, vent, vents, windows
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
