Sign in using an external account
E-Class Coupe (C207) & Cabrio (A207) 2010-: E250CDI Coupe, E350 Coupe, E350CDI Coupe, E500 Coupe, E550 Coupe [Coupes & Cabriolets] |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2012 E550 Coupe
CLS 550 0-60 in 4.2 seconds
#2 | |
Drives: '12 E550C,'13 1LECamaro, Sierra Denali
Quote:
![]() Don't know what the 0-60 time is for this car: "I just had a friend do his e550 4 matic 2012 RENNtech ECU tune only at the track 12.528 at 111 mph" Found this post in the Tuning forum. Last edited by Dueclaws; 08-01-2012 at 06:08 PM. |
#3 |
Drives: 2012 e550 cabriolet, 2012 E350 Sedan, (wife)
Our cars are quite traction limited. Even with 275/30/19 Michelin Pilot Sport rears, I can't floor it from a start (not something I'd want to do more than a few times anyway) without getting wheelspin, and lost time. I'd figure low to mid 4's is more accurate, but who knows. I did play around against a 2012 CLS 550 from about 20 mph and felt I was at least his equal. We didn't go for long though as we were on a public freeway.
#4 |
Drag Strip times are meaningless unless you know the weather conditions and the track starting line prep. Temperature and barometric pressure can easily vary horsepower 10% in the normal range at sea level of 60-100 F and 29.8-30.4 psig barometric pressure.
Starting line prep is another story altogether. If you go on a street car test and tune night the starting line will be torn up almost immediately from people using street tires. If you want to get a decent starting line prep enter a weekly race for race cars on slicks. You will get beaten first round but you can get a better indication of car performance without excessive wheel spin off the line. |
#5 | |
Quote:
#6 |
Drives: ///AMG
was the cls a 4 matic model? That would help big time , as the coupe is traction limited
__________________
![]() Custom steering wheel/kleemann headers w/ceramic coating/custom downpipe+xpipe/kleemann 80mm TB kit/ SC pulley/ EC V2 tune ______________________________________ Family's MB's:12 E350 4matic, 09 S550 4matic, 04 E55, 13 GLK350, 14 S-class on order |
#7 | |
Quote:
#8 |
Drives: '03 SL500, '10 E350 sdn, '12 E350 sdn
Replacing stock A/S 255 tires by sticky/summer (like Michelin PS) 275 is a must. Keep in mind that wheels will need to be replaced as well.
__________________
Current cars: '03 SL500 Sport Slv/Blk on 20" HRE 544R & 20" OZ Opera PL '10 E350 sdn Sport Wht/Blk Pano P1 on 19" AMG VI CL/S replica '12 E350 sdn Sport Wht/Almnd-Blk Pano P1 on 20" OZ Galileo III & 20" OZ Leonardo III Previous MBs: '10 E550 cpe, '09 E350 4matic, '03 E500, '02 ML500, '00 ML320, '00 CLK430, '00 E320 4matic, '99 CLK430 Most significant previous others: '05 Audi A8 '01 Audi A6 4.2 Sport '97 Toyota Supra '90 Nissan 300ZX '87 Mazda RX-7 |
#9 | |
Quote:
If you want "super" sticky go with the Michelin Pilot Super Sport. The new M5 BMW has these. I imagine they wear relatively fast, but the PSS received good reviews in the latest Road & Track comparison of the new M5 vs. CTS-V. |
#10 |
I find all this complaining about the stock tires amusing. MB did not design the E550 to be a race car. The tires on the car are there to provide a good ride and reasonable mileage. The traction control does a really good job of taking care of the wheel spin in straight line acceleration.
If you are looking for straight line traction going to larger wheels is barking up the wrong tree. Narrow stiff sidewalls don't give better traction in a straight line. Their purpose is to keep sidewall roll to a minimum in cornering with the sacrifice of some ride quality. If you don't believe this take a look at the tire sizes made for purpose built drag race cars. You won't find a wheel size any larger then 16 inches and most are 15. They also have very flexible sidewalls to allow them to flex and make a larger footprint when the weight transfer to the rear of the car during acceleration loads the rear tires heavily. They are terrible for cornering and is one reason you see purpose built drag cars have such a hard time steering when they get crooked; the tires roll over onto the sidewalls. Large wheels with narrow sidewall tires may look better and corner better but they add nothing to straight line acceleration and the stiff sidewalls are in fact a hindrance. |
#11 |
The tire size issue isn't limited to the E Coupe, the C63 comes with 255 rears too... and it is a performance vehicle.
#12 |
ronsc1985, where in my post did I say that one must switch to a larger diameter wheels? One must switch to wider than stock (8.5") wheels (regardless of diameter), since 275 series tires (275/35-18 in this case) do not fit on 8.5" wide wheesl (minimum 9", ideally 9.5"). BTW, this will also increase (not decrease) sidewall height, hence greatly increase traction.
__________________
#13 |
This really is an interesting topic, and obviously there are members here who know their stuff. I speak only from my own personal experience. The 255 primacy tire that came on both my 2011 and 2012 E550 Cabs are a really nice tire, and I understand why MB chose them in this application. I put them on my Mom's C350 Coupe in 255/18 as well. They offer a quiet and comfortable ride and get good milage. The car really is a nice driver with them. I changed to the 275/30/19 PS2 because I wanted a more spirited drive from my car. It's still nice, but certainly a bit noisier and slightly harsher riding. But that's what I was willing to trade off. Regarding acceleration, and having both set ups in both 550 Cabs, I can say that the width difference and tire compound does make for a bit less wheelspin. Incidentally, we have a similar size set up on a 2009 M3 in the family with the newer Pilot Super Sports replacing the worn PS2's on it. The SS is a far superior tire from what we noticed so far, and will be on my car when mine are done. And yes, the new 550 is more than a match for the 413 hp less tourquy M3, at least in a straight line. Lastly, regarding the traction control, MB's system has gotten better with each generation. I remember thinking both my 500 and 550 CLK's were quite dangerous in the way that the system cut engine power at the slightest hint of wheelspin, often even before I could detect it. The power took seemingly forever to come back on, leaving you hanging sometimes in a bad spot. The newer system doesn't seem as interrupive. Seems they are getting it right just as I'm getting too old and responsible to take advantage of it. lol
#14 |
Can I just switch out the rears for 265 Super Sports?
#15 | |
Quote:
Doing what you suggest also results in a 2.2% equivalent higher rear end gear ratio which may also quiet down the wheel spin some if that is a problem you are having. I haven't experienced excessive straight line wheel spin ever with the stock tires. Last December when I first took delivery I tried on really cold days to induce straight line wheel spin and the traction control seemed to keep it in check nicely. I was doing this since my previous car, a C6 Z06, lit the tires hard in first, second or third on such cold days. The only thing the GM traction control did was keep you from hitting the rev limiter (usually). The MB system is far superior. Maybe they perfected it in F1 before it was outlawed. What the traction control doesn't so so well is limit wheel spin when accelerating hard out corner in the lower gears. It's not bad but definitely a lot worse then straight line, but of course the lateral weight transfer make the job a lot more difficult. |
#16 |
Drives: 04 MB E55 AMG (MINE); 06 Jag XK8 Victory Edition Vert (HERS); 1997 Pontiac Sunfire (work mobile)
The only problem with that is the "traction control" uses the brakes to control wheel spin which, in turn, slows the car down. If you can find a way to get traction without using the brakes to control wheel spin, you'll be faster
__________________
#17 | |
Quote:
I think MB did a good job at evaluating the tradeoffs to provide a really excellent street car that has decent acceleration, handling, ride quality interior room and fuel efficiency. The only thing I wish is it had a little wider trunk. Someone should tell the Germans that modern drivers are 45 inches and longer. In order to fit my golf clubs in the trunk I have to put them in at an angle or take the driver out of the golf bag. |
#18 |
^LOL @ the golf clubs part. Your point about detrimental effects are some what valid. However, a slightly wider & stickier tire wouldn't be that detrimental. Also, I dont see how the addition of a good lsd set up would be detrimental at all.
__________________
#19 |
#20 |
ahhhhh I see
__________________
#21 | |
Quote:
Not to say an LSD wouldn't be a net gain but there are also downsides. In particular LSD with clutch packs need to be warmed up to be effective since the clutch packs are set up loose at ambient temperature to account for thermal expansion so that the clutch packs can slip at all when warm. When cold they are pretty much like an open differential. I found this out years ago when drag racing a LSD car. First run of the day it would go crooked then it would be O.K. unless there was a long delay between rounds or the weather was on the cold side. One night in the fall I almost took out the tree and the starter when the car made a left turn during a 6K rpm launch. This was in a final and cost me a grand. I bought a spool the next day. All this is not a problem with a street car since you have usually run it for a time before attempting to hard launch it. The above is primarily why people drag racing bad mouth LSD's and prefer either spools or locker rear ends. |
#22 |
A Torsen style like Quaife is a good LSD, they're heavier but don't create a problem with ESP & are durable. That's why we "tried" to install one.....
#23 |
Do tell
__________________
#24 | |
Quote:
I concur. Straight line wheel spin can be controled even with stock tires, but IMHO a bit less so in more powerfull 2012 E550. However, when accelerating hard out of the corner (even in my relatively "underpowered" 2010 E550) back wanted to come around every time on stocks. I removed stocks soon after delivery and am happy with results - 275/30-19 and 265/30-20(intentionally used higher diameter to "control" wheel spin, which it does).
__________________
#25 |
Funny about the clubs Ron. Just got back from golfing myself. Always a pain with the driver. If the trunk was just an inch or two wider it would fit. Not a big deal though.
| Tags |
| 060, 2002, 2009, 2012, 207, 550, amg, beat, cls, cls550, coupe, coupes, e550, horsepower, renntech, seconds |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
