Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Remove Steering Wheel
Step by step instructions for do-it-yourself repairs
DIY: Steering Wheel Swap
Swap chip
Ok, I will give a better explanation. There is a board which link to the brown connector. It's inside the steering wheel. When you swap that board from your old steering to the new ones, everything will work including horn. Hope that help whoever doing the project.
Does anyone have an explanation of how to swap the board over, before I disassemble two completely good steering wheels
Pictures would be GREAT, as I assume the board from a 2010 wheel will not fit nicely into a 2012+ wheel, the dimensions are totally different
I just discovered I need to do this as well, I swapped over the steering wheel but none of the buttons / horn worked.
new board will cost you 150+ euro. let me know if u need new board.
#32
#34
E350 CDI Coupe W207
Good morning all,
I'm new on this forum and have a question regarding the steering wheel swap.
My car is a E350 CDI Executive Coupe black with 18" AMG Wheels
My question is the following:
I plan to swap my steering wheel from the actual without shift paddles to the new one with shift paddles.
I'm just wondering if the shift paddles would work or if I have to buy or do something to make it work?
Many thanks for your help.
#37
Good morning all,
#38
Thanks for your reply.
I didn't tried to remove the SteerWheel in order to check if the connectors are available as "factory pre-installed"
I have two questions:
1 - Does anyone has already the answer for the "factory pre-installaed"?
2 - What should I do to make it works as you Dav?
Peace!
#39
E class steering wheel swap.
Hi I'm fairly new to the forum and I've been following this thread with anticipation of changing my black steering wheel from my 2011 A207 220 cdi to a 2012 chrome surround with red stitching taken from a A250 2012 model bought from EBay with matching airbag. Also bought from EBay new. With not having access to a T30 torqx key and an apprehension of doing it myself I took it to Mercedes franchise . All went well until they tried the steering wheel commands and then no communication between the wheel and the commands. They informed me that the software was not compatible between the two. Yet after consulting with a couple of Merc technicians they said there should be no problem. So at the moment I'm stuck in the middle of the deep blue sea not knowing which way to turn.
Please any help to resolve my problem would be truly grateful. Thanks in advance.
#40
Please assist
Hi I have a w204 c class 2010 model.
I installed a 2012 flat bottom steering today all fits perfect and drives fine.
However the horn button controls light on steering and trip gears are not working.
Any 1 have a clue what I need to do to get it all working
#41
Yes, buy a new contact plate for models prior June 2012. Your new steering wheel came with new plate. If you need one let me know, I think I have something. Send me photo of steering wheel , your VIN number , and serial number on steering wheel ( can take a photo of it )
#42
The new steering came with only steering and airbag not sure what the contactor is.
I'd appreciate it if you could get it for me how do I go about contacting you
#43
It's located inside steering wheel on 4 screws as I remember , just beyond the airbag. If you want one drop me details I asked you and delivery address, so I can give you a quote.
#44
Details that you asked for.
Picture attached
VIN WDD2040022A361531
Previous steering wheel
New steering wheel 2012
#45
Has any one had the same issue fixed
Please any help would be good.
Am new to this changing from factory installed equipment so I won't know what chips and plates are so please a good clear explanation would be apreciated.
Thanks in advance.
#46
does anyone wanna sell there older steering wheel to me i need it complete
#47
Hi has any 1 had the same problem as mine and solved the problem if so please help am stuck with a fantastic looking wheel but no good without the functions and horn.
Thanks in advance.
Thanks in advance.
MJF (07-26-2016)
#48
#49
I just had mine sorted
There is a chip inside the old wheel. Like a small circuit board. You need to fit that in the new wheel with the help of an electrician. I did it with the help of a guy that worked at Mercedes and was also an electrician. The board will not fit correctly so it will need to be cut but don't do it yourself.
I'll send details later today
