Dyno Results - Eurocharged Stage 2 - M278 E550 Coupe
Old 05-18-2015, 05:24 PM
zulumerc's Avatar
ECS Supercharged C6 Corvette& 2012 E550 Coupe
Wow, I was just looking at the manual too and came across that page, it does say:
Gasohol, a mixture of 10% ethanol and 90% unleaded gasoline, can be used.
Old 05-22-2015, 03:48 AM
TopGun32's Avatar
Originally Posted by PaulE550
Question: The owner's manual for the E550 (page 376 for 2015 model) says to NOT use E85 as it may cause engine damage. Is this now inaccurate? I know ethanol can have a corrosive effect on the fuel system over time. Especially as the percentage of ethanol to gasoline is increased. Has MB done something to eliminate this problem associated with higher percentage ethanol use? Thanks.
I can only speak on personal experience. Do your research and you will find a concesus about using certain mixes. Bimmer forums are the best source. MB owners tend no to look into E85.
I'll give you a clue. E20 or E30..
Would i run all E85 on my car, no I would not. Can I treat at as race gas and only use to boost octane. Yes I would.
For a stock tune.. it might help a bit.
Old 05-22-2015, 10:19 AM
PaulE550's Avatar
2015 E550 Coupe
OK. Thanks for answering my question TopGun32. Very informative. I think I'll stick with what's recommended in the MB manual as I don't track my car. Thanks again.
Quick Reply: Dyno Results - Eurocharged Stage 2 - M278 E550 Coupe
