Install rearview camera????
DONE and working!!!Install rearview camera?
Anybody installed a aftermarket rearview camera on 2012 coupe with Comand NTG4,5?
Have seen a DIY in C-Class forumhttps://mbworld.org/forums/c-class-w...der-200-a.html
but im not sure if i can follow this DIY.
Do i need http://www.ebay.co.uk/itm/Veyron-VI-...item3a779e6ba2?
Any thing else???
Thankful for all tips
Any thing else???
Confirming that install a cheap backup camera will work on a 2012 coupe with Comand.
I have not installed the camera yet,when the picture was taken the camera was held by my daughter
Got the wrong cable housing from the supplier, but just removed the housing on this one
And NO NEED OF Camera/Video Interface
And i used this camera
http://www.aliexpress.com/item/Free-...213023810.html
All i did was to look at this https://mbworld.org/forums/c-class-w...der-200-a.html
I paid about 24USD for the camera and Facra to Rca cable
I used this
to find out how to remove the comand.
Its actually easier to remove the vents on 207, i only needed to remove the vents and then unscrew the two screws on the Comand
And i used the left green connection with pink to connect Fakra to RCA
I have only tested that the camera works, but im not finnished to put the cable where it should be(under the carpet, passenger side).
I ned to know how to remove the sidepanel right side
And you need the green fakra TV1 6002 E on this picture
I used this
I used this
I need some help to remove the sidepanel rear right side, because i want to put the cable under the carpet, so please comment and give me some hints
I used this
So im sorry for my grammar and spelling, but i try my best.
Here is the final picture of the screen when backing up.
Sorry about the dirty car, its been raining her all day!!!
Can I also fit a camera ? I have an A207 WDDKK4JF7DF187615 with the V20 sound system.
take a look here
