Rotor Toast?
1 Post
2018 CLS550
Rotor Toast?
Just noticed this. Got back from a few day trip for work and had to fill up a tire. As I filled it up, I noticed 2 indents in my rotor. It's only on the front passenger.
Is this rotor toasted?
2012 C63; 2011 E350 Coupe
Those cuts in the rotor look too deep to turn the rotor down.
I'm guessing the rotors are toast. You also have something embedded in the pads that cut the rotor. They will need replacing as well.
With that deep of a cut, didn't you hear unusual sounds when applying the brakes?
1 Post
2018 CLS550
Well that does suck....Nope, Not a single sound and I usually drive with the windows down. I did notice when I stepped on the brakes that my car pulled a bit to the right, but it was because the front right tire had 20 lbs of air in it.
E350 Coupe
im having a problem with my rear brakes eating the pads unevenly. im going to take them off and see whats wrong. i think you should take off the wheel and just have a peek. might be a bad brake pad
