Wheel offsets 19x9 19x10
Will these work on the E Coupe: in your opinion?
I've searched the forum, but haven't found this exact combination of offsets.
Front: 19x9" ET37
Rear: 19x10" ET47
If the offsets will work, would like to use 245 or 255 fronts with 275 or 285 rears
Front: 19x9" ET37
Rear: 19x10" ET47
hey...
those offsets will work but to limit rubbing you may want to run a smaller tire.
keep in mind that tire brand is very important - some run larger than others.
19x9 - 245/35/19
19x10 - 265/30/19
are you on stock suspension? aftermarket springs with a higher spring rate will also reduce rubbing.
19x9 - 245/35/19
19x10 - 265/30/19
Stock suspension.
It's important to run larger tires in the rear because of the torque and tendency to spin.
A quaife would fix that: I know.
2012 E550 Coupe
Can't comment on the front. Just don't know.
Thanks Venom
both front and rear are tight and 2mm and make a difference.
This will take some thought: can't take the risk to buy the wheels, tires and then find they won't fit correctly.
Due,
I have 45 et rear and 285 AS3's. Very minimal rubbing if I have 4 people in the car and go over a dip. But in a perfect world I would love to have those extra 2 mm. It's the outside that's a bit tight, and a higher offset would help. I heard somewhere that 48mm is perfect...Hope this helps. BTW, when I had the 275's on the rear there was absolutely no rubbing under any circumstance.
2012 E550 Coupe
All I can do is share my current setup experience. But in fairness, if you are concerned then consider going with a bigger offset. Especially if you think you might lower the car in the future.
Due,
Due,
