Problems with GPS on 2010 E350 Coupe
Old 11-22-2014, 04:14 AM
Rorie's Avatar
2015 Mercedes-Benz C63 AMG S Edition 1, 1995 Ferrari F355, 2004 Mini Cooper JCW MC 40, 1967 MGB
My Dad is having issues getting the GPS to work. It keeps defaulting to a location in the middle of no where. I did some searches. It seems the box is in the trunk on the left hand side. I unplugged an orange cable and then plugged back in. There is a pic attached of what I did. I also did a reset of the system.
Anything else someone can suggest as the GPS still does not see satellites.
Attached Thumbnails Problems with GPS on 2010 E350 Coupe-e350gpslefttrunkarea.jpg
Old 11-22-2014, 04:53 AM
alzieboy's Avatar
E350 CDI SPORT COUPE
Have read a number of posts on the same subject, they all appear to point the finger at the Antenna which needs to be changed. This seems to be a common fault. One firm suggest getting a new Antenna plug it in while just letting the Antenna lay loose on the roof of the car to check that the satellite signal is picked up okay, then of course you need to install it .
Good Luck
Quick Reply: Problems with GPS on 2010 E350 Coupe
