where is loom connector for shark fin antenna
2010 e350 coupe
hello all. I damaged my shark fin and I bought a new one. however to fit the new one I need to locate where the cable connectors are in the car pls. its easy to change the actual antenna simply by removing rear map light and using large star screw but I'm hoping to avoid removing head liner to find the loom connectors (2) for the new antenna.
many thanks all
many thanks all
Try this
Why not just remove the head liner? You might uncover the fact that there are a bunch of shell companies underneath designed to entrap customers. As for the connector, I'm sure you'll find that it fits comfortably up your dean.
