20" Wheel offset questions Rohana RC26
I am looking for help regarding offsets for my 2010 e550 coupe. I am looking to buy 20" Rohana RC 26's and what to know which would be the best possible fit.
20x9 Front (Available offset 25,35,45)
20x10 Rear(Available offset 33,45)
looking for some help to guide me which offset will best fit my car. I will be using stock springs no lowering. Also possible tires sizes please! Thanks.
-Steve
-Steve
I think you want higher offsets (45 in your case) to push the wheels out to clear the front struts and the rear wheel well lining.
2010 E550 Coupe
Et45 rear on 20x10 should be pretty flush. I run 20x10 rear ET50 on mine to be on safe side of no rubbing and it sits just barely inside wheel well. As for front, I'm perfectly flush on 20x8.5" et35 but since your wheel is 1/2" wider you may want to adjust accordingly with the et45. It will prob also be just inside the wheel well but should clear the strut as long as your tires aren't too big.
