19 inch wheels for A207
Old 04-10-2015, 11:55 AM
puneet211086's Avatar
A207
Thumbs up 19 inch wheels for A207
Hi guys,
I am planning to buy 19x8.5(front) and 19x9.5(rear) rims 35mm offset for my 2011 e350 cabriolet. I am not sure if its going to make much difference in the look of the wheels or not as compared to 17 inch factory wheels. Or should I go for 20s. If its worth going for 19s then what size tires would you recommend that I can go for without making any modification to the axle. Thanks.
Old 04-10-2015, 06:26 PM
GerryMac's Avatar
2012 E550 Coupe
A -35 offset should be just right for the front 8.5" wheels but will be too aggressive for the rear 9.5" wheels. You probably want to be around -45 on the rear to be aggressive without rubbing.
Old 06-27-2015, 11:15 PM
A207
So what tire size would you recommend?
Old 06-29-2015, 05:00 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
I have the same size set up on my E400 coupe and am running a 245/35/19 front and a 275/30/19 rear - lowered 1.6" with no rubbing at all.
Old 06-29-2015, 11:41 PM
A207
will it be same for 2011 E350 convertible A207 as well?
Old 06-30-2015, 11:15 PM
tak06's Avatar
2012 E350 Coupe Sport Package
I just ordered the same setup 245/35/19 front & 275/30/19 rears on Niche
M146 Rims fronts 8.5 x 19, offset 42mm and rears 10.0 x 19 offset 55mm for my '12 E350 Coupe, OEM Sport Suspension height, I'm concerned about the rear clearance with the 10" rims, do you think there maybe an issue with the rear or will the non aggressive rear offset compensate?
Old 07-02-2015, 03:24 PM
GerryMac's Avatar
2012 E550 Coupe
[QUOTE=tak06;6482956]I just ordered the same setup 245/35/19 front & 275/30/19 rears on Niche
You will have no problem with rubbing on the fender, I run 19X10et50 rears with 275/30/19 Conti DWS and no rubbing ... the concern should be more about rubbing on the inside of the wheel well. There probably won't be an issue as the 275 on a 10" wheel is a bit of a stretch fit and should provide enough clearance.
Good luck with the new rims, the M146 10-spoke should look very nice.
Old 07-02-2015, 03:40 PM
~ also my rear wheels are a 50mm offset in a 9.5" width. Hope this helps.
Old 07-11-2015, 10:46 PM
tak06's Avatar
Just installed my M146 Essens: 8.5x19's Offset +35 and 10x19's Offset +55
on 245/35/19's and 275/30/19's.
the rims/tires are almost flush to the fender lip, no clearance issues
Old 07-12-2015, 11:25 AM
SnakeDoctor's Avatar
2014 E550 Coupe and 2010 E350 Sedan
I like!
Old 07-12-2015, 02:03 PM
tak06's Avatar
Thanks, love to get a E550 Coupe someday.
Old 07-17-2015, 04:14 PM
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
Wheels look great!
Old 07-20-2015, 11:53 AM
Anttribb's Avatar
2015 C300
Nice! just remove that chrome molding strip on the doors and it'll be perfect
Old 07-29-2015, 07:55 PM
Originally Posted by tak06
~ your car looks great! Nice work!
Old 07-29-2015, 10:53 PM
patrickkc's Avatar
E63S || C63 || E550 Coupe || Cayenne ||
Wow, those wheels are beautiful!
Old 07-30-2015, 01:03 AM
tak06's Avatar
Thanks for the compliments everyone, these are merely Niche alloys rims, reasonably light (I don't notice any difference with the slight increase in weight) & priced, are MB Hubcentric and accept MB Center Caps.
Old 07-30-2015, 11:40 PM
ffr2014's Avatar
Removed my chrome strips and "Blue Efficiency" badges and definitely looks better without! Will post pics to my new thread:
https://mbworld.org/forums/e-class-c...550-coupe.html
Old 07-31-2015, 01:07 PM
tak06's Avatar
I guess it's subjective, I kind of like the chrome BSM., having said that, I did remove the BSM on my Z06 and my son kept his on, I think on this car it looks better without.
Without;
with:
Old 07-31-2015, 01:41 PM
ffr2014's Avatar
Without;
with:
Agreed - it looks better without on the Z06 (nice rides).
Old 08-01-2015, 04:12 AM
NorCal510C207's Avatar
E 550
Nice wheels, hows the ride quality compared to stock?
Old 08-01-2015, 12:45 PM
tak06's Avatar
I guess it depends on the tires one chooses but I picked the Falken FK-453's and I find no notable difference in the ride quality, it's less noisy, handles better & feels planted,
I suppose it's the result of lower profile, larger width Falkens, having said that, these are soft compound summer performance tires and I don't expect a long tread life.
Old 08-10-2015, 11:08 PM
ffr2014's Avatar
Better handling should be expected with the up-size and the summer performance tires. Would you say the comfort level is similar (i.e. soaking up bumps)?
Old 08-10-2015, 11:10 PM
patrickkc's Avatar
I find the Falkens are good too. I am running the FK-453 on my C63 and they're pretty good.
Old 08-11-2015, 01:23 AM
tak06's Avatar
I honestly don't notice any difference in the comfort, with the aspect ratio decreasing on the front tires from 40 stock to 35 & rears from 35 stock to 30 but with the coinciding increase in width, fronts 235 to 245 and rears 255 to 275 there is still is plenty of sidewall rubber to soak up the bumps, now if one goes to 20" rims that would necessitate aspect ratio of 30 front & 25 rears which my son uses on his Z06 and I do notice a slightly rougher ride vs my Z06 on 19" rims on aspect ratio of 35 & 30, (we both use 275 fronts and 305 rears)
Quick Reply: 19 inch wheels for A207
