Regarding 2011 Mercedes E550
Old 04-19-2015, 12:12 AM
enizan's Avatar
2008 Mercedes-Benz E350 Sport
Guys, I'm new here and I would like to get a suggestion from E-Class experts here. I'm looking to purchase 2011 Mercedes E550 with 45,351 Miles on it and since this is a private purchase and I don't want to end up with a bad vehicle, what would you suggest that I check? or should I ask the seller to take it to the nearest Mercedes dealership? I'm assuming I'll be the one paying for the checkup.
Thanks!
Old 04-19-2015, 10:08 AM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
I would be certain to run a car fax and have a certified mb mechanic put the car on a lift and check it over.
Old 04-20-2015, 09:36 AM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
Find out where they had the car serviced. The seller should also have all the service records.
If the car was serviced at an MB dealer, the dealer will have a vehicle history.
Old 05-05-2015, 04:12 AM
enizan's Avatar
I actually did check carfax, looks clean but I was in the situation when some reports are not fully reported to carfax. Thank you for the tip!
Thank you for the advice! I did email the seller to find out if he has all of the service records but no reply yet. Hopefully the vehicle is not sold.
Question: I was curious about the acceleration from zero to 60 mph when googling found the following:
http://www.autoblog.com/buy/2011-Mer...expert-review/ (states 5.1sec)
http://0-60.reviews/mercedes-0-60/ (states 4.6sec)
http://www.zeroto60times.com/vehicle...-60-mph-times/ (states 4.9sec)
Which one is correct or none of them are?
Thank you in advanced!!!
Old 05-05-2015, 11:09 PM
$100 GUY's Avatar
C207
Look, the car does it in 4.8s with 1 foot rollout.
I´ll say 5 flat or 5.1 is more accurate, in fact, 5.1 is the 5-60 number. More real world like.
But what is the big difference between a 10th of a second there or here?
You are going to the dragstrip with a 2011 E550?
Old 05-06-2015, 12:55 PM
enizan's Avatar
Thank you for the info! Not really but its good to know the actual number.
Old 05-06-2015, 01:42 PM
msheredy's Avatar
MB
There are many minute variables that play into performance numbers (DA, elevation, road surface temp etc). If the numbers were off by a second or more then we could see your point but like $100 Guy said regarding 10ths of seconds, "What is the big difference"?
Old 05-06-2015, 09:17 PM
$100 GUY's Avatar
C207
No worries man, you can go quicker very easily with an E550, just buy a newer model
Old 05-15-2015, 03:07 PM
enizan's Avatar
Sounds good but if I decide to get a newer model 550 I might as well go with used 2010-2011 E63 (same price range)
Just got a call from a local Mercedes dealership, currently under inspection and price tag will be around $55K to $65K
Old 05-15-2015, 03:20 PM
enizan's Avatar
True! Its educational for me so now I know its not much difference
Quick Reply: Regarding 2011 Mercedes E550
