ECU and TCU questions for A207
2012 E550 Cabrio
I have a '12 E550 that I want to flash the ECU and want to gain around 80-100 HP.
Q1- who do u recommend for me to talk to? About how much should I expect to spend?
Q2- do I have to do a TCU upgrade? What's the benefit?
Q3- would there be a noticeable difference if I only upgrade the ECU instead of both?
Q4- what's the best radar detector these days to keep me from my losing my license after the upgrades??
Thanks in advance for ur help.
Mercedes E350 CD Iridium silver convertible 2010
Hi ! I see you have black trim, did this comes as standard or have you have it done?
I ask because the long chrome strip on my rear panel where the rear window of the soft top closes onto to seal, has lots of hazing in it that is under the lacquer and cannot be polished out.
Mercedes refused to take responsibility when it was under warranty, mostly because that strip is very expensive and I was told it is quite involved process to remove//// thanks
2012 E550 Cabrio
I had all of the trim painted black. I'm not sure what it's called, but it is removable and supposedly will hold up.
I didn't wrap it because I was told since I live in DC metro and the weather fluctuates A LOT, the wrap would stretch and not look good after a few months.
ECS Supercharged C6 Corvette& 2012 E550 Coupe
There is no TCU upgrade for the vehicle the remapped ecu will make the overall drive feel better. I would recommend going with KLEEMANN i have the catless downpipes and the tune. It is amazing!
Hmm I just noticed the Weistec 722.9 Valve Body upgrade. It seems a little over priced. Has any one done this before?
http://weistec.com/all/e/e-550/2012-...u-upgrade.html
The "M" mode in AMGs and some very new non-AMGs sticks with just one gear as long as it can.
2012 E550 Cabrio
I just looked into Weistec and although their numbers are impressive, I'm not impressed with the $2550 number!!
Why do these tunes cost so much??
I was hoping to find a tune under $1500 but I'm not having much luck!
Any other suggestions?
Kamtrac, contact Kleemann they have tuned several bi turbo e550s and are around the price you are looking for.
Squid you are correct, did not realize that is what you meant with the trans holding the gear for as long as it can.
That is one costly trans updrade...I wonder if anyone has done it.
2012 E550 Cabrio
I just sent my ECU to Eurocharged for upgrade. Hoping to have it installed this Thursday and opening her up that night! Good thing my radar detector was delivered today!
