Will I RUB??
Old 11-17-2015, 10:20 AM
tw8715's Avatar
E550 Coupe
Will I RUB??
So my e550 coupe is lowered on eibach and in the rear have 19" rims by 9.5 with 38 offset. The tires on them are 19/30/65 and i am not rubbing.
But the rims stick out more than the tires and i wanted to go 275. Does anyone know if i would rub?
thanks!
Old 11-17-2015, 01:47 PM
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
+38 Offset seems pretty aggressive for rears (I run +45 on 19x9.5 w/ 285/30-19 tires but am not lowered but I think I would be fine lowering slightly). Going from 265 to 275 should not be an issue but not sure with +38 Offset. Can you send pics? How much does the 265 width tires clear the fender when compressed (can see this slightly by jacking up opposite corner or on flat pavement with a wood plank under the tire)?
thanks!
Quick Reply: Will I RUB??
