TIRE SIZING
Old 04-18-2016, 07:43 PM
imaginetigers's Avatar
ecoupe
TIRE SIZING
I have a 10.5 et 45+ 3mm spacer rear wheels with continental dws 285/30/20 and currently have alignment done after H&R springs, and it start rubbing the fender. (looks like its rubbing the tire sidewall, but im not sure.)
I did some research on tire section widths, and realize summer tires with 285/25/20 is .2 inch thicker than my all-season tire right now, but 1 inch less in the overall diameter.
So, will it help if I downsize to 285/25/20?
or should i go for 275/30/20?
my front is 245/30/20 and its working fine.
does the rear tire aspect ratio has to be lower than the front?
Old 04-19-2016, 12:36 AM
ffr2014's Avatar
2012 E550 Coupe, 2013 Escalade ESV, 2013 Lexus GS350, 2003 Honda VFR, 2017 Yamaha Kodiak 700 EPS SE
285/30-20 is too tall, 285/25-20 should work.
Old 04-19-2016, 12:41 AM
ecoupe
thanks for your comment!
do you know why we should keep the front and rear overall diameter the same ? My shop was telling me i should go for 30 aspect ratio for the rear because its a Eclass. I doubt it tho.
Old 04-19-2016, 12:49 AM
ffr2014's Avatar
30 aspect ratio for 285 on 19" is fine for rear but not 20" as diameter is too tall and would create significant error with your speedometer (and handling may also be impacted with significant difference in tire diameters between front and rear).
Also the rear should be fine without the 3mm spacer and give more clearance from fender lip to tire.
Old 04-19-2016, 01:00 AM
ecoupe
The spacer was suggested by the shop too, i think its because the wheels is 10.5 inch wide but again I wasnt sure about it. They said there is no room between the wheel and the inner panel without the spacer. They even said that 25 for rear would look too thin and ugly, I dont have much experience for tires as its my first car.
Old 04-19-2016, 09:52 AM
ffr2014's Avatar
Gavinccm is running 20x10 ET55 285/25-20 rears here:
https://mbworld.org/forums/e-class-c...mer-forum.html
So if you plug into wheel offset calculator for your 10.5" wide ET45 wheels, you will have 4mm more inner clearance (inside of wheel to strut housing) (outside edge of wheel will extend out or poke 16mm more). As your wheels are 10.5" wide the 285 tire will sit slightly more stretched than the 10" wide which should also give you more clearance from the tire.
Old 04-19-2016, 03:02 PM
ecoupe
Just ordered 245/30/20 285/25/20 falken 453, wish me luck.
Old 04-19-2016, 03:54 PM
ffr2014's Avatar
Good luck! Post pics with your new shoes!
Just ordered 245/30/20 285/25/20 fallen 453, wish me luck.
Old 04-19-2016, 03:59 PM
ecoupe
Yea,The tires are arriving next Monday, I will upload pics after!
Old 04-20-2016, 04:53 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Look forward to the pics. I also done this setup on mine.
Old 05-03-2016, 04:33 AM
ecoupe
finally got new tires today, definitely looks better than Continetals.
Old 05-03-2016, 05:49 AM
ecoupe
I think the front and rear wheel gap is still quite unbalanced ,any suggestions for this issue? My eyes are itchy when the front looks higher.
Old 05-03-2016, 08:38 AM
ffr2014's Avatar
Maybe mild lowering springs for the front?
Old 05-04-2016, 01:17 AM
ecoupe
The problem is you will never know how much its going to drop, the amount on specification is a average number. Nothing is promised when you have springs.
Old 05-04-2016, 04:31 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
had the same issue with my old 211 and solved it with coilovers.
nice looking coupe you got there mate! how did you black out your window trim?
Old 05-04-2016, 08:12 PM
ecoupe
Vinyl wrapped
Old 05-31-2016, 12:15 AM
AMJAM's Avatar
E250CGI AMG Coupe
If you don't mind me asking where did you get all the carbon goodies and the front bar?
Old 05-31-2016, 02:39 AM
You find it all quite cheap on ebay...
Old 05-31-2016, 02:45 AM
Had the same problem on mine. Fix it by changing the upper rubber ring. They are sold OEM in different hights. They are marked with dots. The more dots the higher it is.
Or give me your VIN number and I can give you the partnumber for the lower ones.
Old 05-31-2016, 11:38 AM
SnakeDoctor's Avatar
2014 E550 Coupe and 2010 E350 Sedan
How does that work? I might have to do this...
Old 05-31-2016, 02:12 PM
Remove the spring and replace the upper rubber....As easy as that.
Old 06-01-2016, 12:19 PM
Have a link to where we can buy these?
Old 06-01-2016, 02:38 PM
ffr2014's Avatar
+1
Old 06-01-2016, 02:48 PM
But they are OEM... Just go to MB and buy them. Usaly 3 knobs is standard. So you need 2 knobs to lower it or 4 to raise it.
ffr2014 (06-01-2016)
Old 06-01-2016, 03:24 PM
ffr2014's Avatar
Do you have MB part numbers for the 2, 3, 4 options? Also would these work on both the front and rear springs or are there different part numbers for the front and back?
Thanks Chris!
Cheers,
Frank
Quick Reply: TIRE SIZING
