w207 rattling over pothole
seems this is quite common
on a road over a pothole or uneven road, it squeaks, rattle and it sounds like its from the back - not sure why. any suggestions?
nervous to take it to a mechanic who will look at it for hours and find nothing.
any thoughts?
any thoughts?
Try the simple stuff first. Check out the tub that holds the jack, take it out for a test drive. That damn thing can make a lot of noise that you'd swear is coming from the back suspension. Also the cover for the second battery (if yours has one) can make what sounds like a noise from the shocks going over bumps. Ended up packing mine with some towels/shop rags to quiet it all down. Rear cargo floor can also make noise (take out and test drive easiest thing) - put some weatherstripping tape where it rests against the body. Aside from that, it could be sway bar links or ??? But that will take a bit more to figure out ($$) About 90% of funny noises from these and C class are from the "bucket" thing that holds the jack that screws into the spare tire - the design ends up acting like a big speaker and actually amplifies any noises or rattles from itself and the jack/tools.
