Passenger door window won't auto close
And when it gets to the top it opens back up about 2" and stays there. I hit the switch again and it closes. Sometimes it pops open like when opening the door and stays there until I hear the wind noise and close it. It usually stays closed after that but if you open the door it might not fully roll up the window and I'll have to do it manually.
Using the window switch on either side makes no difference. Back to the dealer I'm afraid...
This is on my 2014 E550 Coupe.
They need re-sychnonising by the sounds of it.
To synchronised close the windows by pressing the switch to the first click (i.e. do not fully depress switch if you have an Express feature). When the window has fully closed, continue holding down the switch for a further 2 seconds. Repeat for each window.
Think this is right for the C207.
Received 4,415 Likes
'71 Pinto
XXBogey (11-08-2016)
Thanks!
I just did this too, using the manual version, which was merely, each window up all the way and then hold for button up 1-2 secs. worked for me.
