Sign in using an external account
| E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: '78 300D, more to come soon!
Tell me what you know...
#2 |
Drives: 1984 300D,82 Volvo Diesel
You can get the Factory Service Manual CD set that covers aobut 98.5% of everthing on the whole car. A bunch of info at an exceptional price.
Factory Service Manual CD Set $19.99+$7 shipping http://www.classictechlit.mbusa.com/MB/product.asp?catalog%5Fname=Retail&category%5Fname= 1009%28ClassicTechLit%29&product%5Fid=QL%2D6516%2D 5610%2D02%28ClassicTechLit%29 Since the Engine has so few miles on it I would not expect problems there. I would be looking for paroblems with the Rubber Parts on the Car if they have not been changed. The Flex Discs on the Drive Shaft The Rear CV Axle Boots The Front Suspension Pivots on the Elasticity of Rubber Bushings. When they go bad you can start to have Tire Wear or Steering Control problems. No need to mess with them until a problem comes up. The main thing is as happen to a member on another forum; He had his car re-aligned. Within a few weeks his Lower Control Arm Bushing on one side became no good. With a car this old if the rubber suspension parts on the front have never been replaced I would do so before having it aligned. Anoter Note if you have to compress the Front Spring. They are at least 3 times stronger than a Gas Cars front springs. The normal Spring Compressors you buy at the regular Auto Parts are not safe. I know because in the process towards changing the Lower Control Arm Bushings I twisted up the Threaded Rod on my Spring Compressors. I replaced it with larger Diameter Threaded Rod and ended up bending those also. I finally made myself a Spring Compressor with 1 inch Diameter Threaded Rod. Or you can rent the proper Spring Compressor from this Forum (I go by Diesel911 on that forum): DIY Repair Links http://www.peachparts.com/shopforum/forumdisplay.php?f=82 http://www.peachparts.com/Wikka/DoItYourSelf Another rubber problem is the Motor Mounts and Transmission Mount. If the Motor Mount on the Oil Cooler side collaspes sometimes the Power Steering Belt cut through the Oil Cooler Hose. If it happens when you are driving you can loose your Engine. Take a close look at your Oil Cooler Hoses. If they need to be changed see the DIY Links. Also take a look at the links that concern maint.; like Valve adjustment. If your heating system has an Electric Auxillery Pump (mine is mounted low on the Fenderwell not far from the Alternator) it has no fuse on it. When that pump seezes up and shorts it also short something in the Climate Control Box (I do not know if you Climate Control is the same I have an 84) and the short in the Box has caused fires in the interior of some cars. The members of one forum installed 3 amp Fuses on their pumps. Well thats all that comes to mind righ off. If you read the DIY Repair links you will get an idea as to what many folks are dealing with and how the fix it. |
| Tags |
| bad, bushings, rubber |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
