E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
vacum problem
Old 06-27-2010, 01:09 PM
kkolsen's Avatar
w123 300 td 1976
vacum problem
hello, i have a mercedes 300td with automatic transmission, youst bought the car, my problem was when i turned the key to stop the engine it took ten secons before the engine stopped after i had turned the key,and it shifts gear hard, and i dident think i had a good servoassisted brake, the hose on the engineshutdown clock at the back of the dieseloump was bad,when i sat on a new one the problem turns, no when i stop the car i cant get it started again because the vacum dosent leave the system when the engine is turned off,i have tryed to shift the vacumpump with no changes so that issent the problem, anyone,what can be wrong?
Old 06-28-2010, 12:33 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Originally Posted by kkolsen
what can be wrong?
The lack of periods and sentence structure are the major issues. Oh, you mean the vacuum problem!
Its usually cracked hoses for the lock system that cause leaks. The plastic hoses in the doors get brittle with age and crack in the door joints.
Lock the driver door and see if that shortens the shutoff time.
Old 06-28-2010, 04:52 AM
kkolsen's Avatar
w123 300 td 1976
i dont have vacumsystem in the doors, and the problem now is no leak,the problem now are that the vacum dosent leave the system after the engine is stopped.so have to reconnect the hose to the vacumstop to get it started again. how shall the vacum leave the system after the engin stops?
Old 09-25-2010, 12:58 AM
dega's Avatar
W123
i have the same problem here
Old 09-25-2010, 01:46 AM
kkolsen's Avatar
w123 300 td 1976
i found the problem in my car,the valve on the hose direktly from the pump to the breakservo was defekt,its easy to check its a one way valve and on my one i could such true it both ways,sorry fore my poor inglish
Old 09-30-2010, 09:32 PM
Outre's Avatar
83, 300D Federal
Well, you are doing the best you can!
I have spent time in Germany, Hong Kong, Singapore and the Philippines and I did not speak their Language and it is very humbling.
Quick Reply: vacum problem
