E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
::ECS Tuning:: K1 Accumulator Spring Kit For Your 123 Chassis
Old 04-30-2014, 03:33 PM
Former Vendor of MBWorld
ECSTuning's Avatar
2012 SLS AMG
Click HERE to order or for more information.
Only $5.65*
Although the transmission in your Mercedes is well made, it is not indestructible, and components inside will occasionally fail.One such component that is prone to failure is the K1 accumulator spring and plunger assembly.
This assembly is located behind a cover on the side of the valve body, and is usually the culprit for the famous 2nd to 3rd up-shift flare that plagues many Mercedes-Benz automatic transmissions.
Now you can fix this transmission shift flare with this brand new K1 accumulator spring and plunger assembly, and get your transmission shifting like new once again.
*Price subject to change.
