E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Radiator Protection Options
Old 07-09-2015, 11:48 PM
Sharpie1's Avatar
1983 300D and 2008 ML350
My 1983 300D had been running a bit hotter than desired - so I did a flush, followed by a fan clutch replacement and finally a radiator replacement. I had a new Nissens put in this week and finally there is a noticeable difference in the running temp - especially when a lot is being asked of the engine.
Despite having hit it with quite a bit of high pressure water spray multiple times before, the old radiator appeared to be full of gunk such as road grime and stuff. I wonder if there is any sort of screen or filter which I could put over the new one to protect it.
Old 04-07-2016, 03:08 AM
OM617.95's Avatar
1982 300D
Nope. Just pull it and clean it every 5 years when you change the coolant.
Quick Reply: Radiator Protection Options
