EGR Replacement
Old 09-02-2006, 10:06 AM
nkpnkp's Avatar
EGR Replacement
How hard it is to replace EGR valve on E320 1995. I have fault code # 5. How expensive is it for part? My mechanic wants $200 to do the job. He will not replce part but wuold rather clean EGR and clean pipe attached to it. I feel it should be replace. Help?
Old 09-02-2006, 10:25 AM
Kestas's Avatar
95 E320 Cabriolet, 108K
I side with the mechanic. This is a common problem. The Code 5 usually results from deposits blocking the egr tube. The blockage is mainly at the few inches where it joins the throttle body. That's where the vapors condense.
It sounds like you have a good mechanic who isn't needlessly changing parts.
Old 09-02-2006, 06:11 PM
GORBETTTEAM's Avatar
'95 3.2 M104
EGR Valve Procedure
Campaign No. 95-0131
January 1995 (RECALL)
FILE: SERVICE: GROUP 00 OF SERVICE INFORMATION BINDER
PARTS: GROUP 1 OF INFORMATION - PARTS & ACCESSORIES BINDER
SUBJECT: ENGINE 104 HFM-SFI
REPLACEMENT OF EGR VALVE
The EGR valve on engines 104 HFM-SFI may stick, causing the "CHECK ENGINE" MIL to illuminate.
On vehicles within the effective serial number range given below, the EGR valve (89) must be replaced during the vehicles next scheduled maintenance or repair.
Note: In performing repairs, check the date code of the valve. EGR valves with a date code 94T174 or later are OK.
Effective Serial Number
Model Model Indicator Chassis End Number Range
124.032 63 1C 130329 - 171168
124.052 64 1C 144825 - 169548
124.066 65 1C 107566 - 170317
124.092 89 1F 290576 - 300405
129.063 95 1F 080769 - 108179
140.032 B1 1A 126931 - 213831
140.033 B2 1A 163478 - 216629
202.028 C2 1F 002506 - 136382
Procedure (SMS, Job No. 14-7662)
EGR Valve
1. Disconnect vacuum line (89/3).
2. Remove EGR line (89/2).
3. Remove nuts (89/1 and 81/1).
4. Remove and replace EGR valve (89).
5. Tighten nuts on EGR valve.
6. Reconnect EGR line and vacuum line.
Parts Information
Part Name Part Number
EGR valve 002 140 13 60
In Case of Warranty
Operation: EGR valve, replace (14-7660)
Damage Code Repair Code Time (hrs.) Model Indicator(s)
14 931 01 12 0.3 63/64/65/B1/B2/C2
0.4 /hr 1989
0.5 /hr 1995
EGR Valve OEM 0021400260 $280.00
EGR Tube OEM 1041413504 $9.75
Old 09-03-2006, 10:31 AM
nkpnkp's Avatar
thanks
Cool. I will let my mechanic do the work.
Old 05-26-2014, 12:57 PM
quest1966's Avatar
1995 E320 Special Edition
Engine Light - Code 5, port 3
I had this code show up on my 1995 E320 (w-124). Research on this and other forums suggested it was most likely a clogged EGR tube. This indeed was the case.
Remove the tube to clean is quite easy if the throttle body is removed first. Here is a helpful link for this project taking roughly 10-15 minutes: http://www.benzworld.org/forums/w124...ttle-body.html.
Once this is off, remove the EGR tube:
1) disconnect the nut at the EGR valve (17 mm open end wrench, I think)
2) detach the small hanger attached to the oil filter housing (5mm alan nut with long extension on ratchet)
3) disconnect tube from plenum - the portion of the intake upon which the throttle body sits (two 10 mm hex bolts)
I was unable to remove the tube from the engine compartment because it was stuck in the EGR tube. Fortunately, with the throttle body off, I could move it around enough to stick a small flat head screw driver into the tube and scrape out the carbon deposits. Lots of chunks came out and this was sufficient to fully unclog the tube without going through the trouble of soaking it with chemicals or trying to ram a speedometer cable through it.
Replace gaskets for both the throttle body and the EGR tube.
This resolved the engine light and code issue.
Old 05-26-2014, 03:51 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Nice job, however why not provide more diagnostic advice(more detail), because there are no doubt loads of forum folks that havent got the FF idea what you mean by-----Code 5, port 3
Old 03-30-2017, 08:04 AM
Airton123's Avatar
w211
For egr system problems. I decided not to make easy money to my mechanics, but ordered a egr valve emulator from web. I got it and instal manualy, works perfect. Recomendet to all. For me there was fully mechanical egr, meulator linked: http://ces24.com/egr-emulator/11-ope...-emulator.html
But in this site is a lot more, cheap price and extra quality.
Quick Reply: EGR Replacement
