definitive wheel fitment guide for w124 pdf
Old 04-29-2008, 03:00 PM
munman_stk's Avatar
W124, W164
hi guys. im pretty much a newbie at this. had a look at the link V9 posted...the list did not include 18x8 ET 31, 18x9 ET 35 (AMGs).
Would they fit the car? and is the 18x9 with that offset too wide for the rears? can i get away with rolling the fenders?
i have a 1989 230E. Please help...
Old 12-20-2008, 08:37 PM
neanderthal's Avatar
if the list doesnt include it, it pretty much precludes them being a direct fit, innit?
now, you could go look at the running gear thread and see if anyone is using that size and offset, and see if they are using a spacer or have rolled thier fenders or added spacers.
Old 12-21-2008, 10:16 AM
AMGDave's Avatar
300D, 500E, E420
Just a reminder, everyone, that list is NOT complete and NOT comprehensive!!
The rear of a W124 can use wheels at least a half-inch wider than the fronts, but that is not shown in the list. And those wheels in the list wider than 8.5" are really for the 500E only (note the "wide wheelarch" comment).
In general on a standard (non-500E) W124, the max width possible without hassles is 8.0 front, 8.5 rear, with the proper offset & tire size (225 on a 7.5, 235 on an 8.0, 245 on a 8.5). Beyond that, you'll have clearance issues, especially on lowered cars, and/or when cornering hard, and it will be worse on 1990-up models with the wide side mouldings (will need to trim the wide moulding at the inside of the front fender).
The 18x8 and 18x9 wheels mentioned in the post above would require massive fender rolling (see the AMG docs I linked to above) and also the fender spacer kit shown in the photo above. If you're thinking about making these work by fitting skinny little narrow tires, forget it. Just get smaller wheels if you're going to use smaller tires. Unless you want to look like a ricer or BMW, with "stretched" tires, lol....
Old 12-28-2008, 11:33 AM
MB-boy's Avatar
W124
THANKS!!!!!!!! AMGDave.
That is a beautifull resource. By the way, the front spacers are pretty clear but what about the back fender spacing. Any opinions,ideas or experince.
I have AMG Monoblocks 17/8.5 in the rear and stock shocks and springs and there is some serious rubbing in the back. (On hard curves and bumps).
Please, if someone can help, I would appreciate it alot!!!!!
Old 12-28-2008, 11:54 AM
AMGDave's Avatar
300D, 500E, E420
Originally Posted by MB-boy
By the way, the front spacers are pretty clear but what about the back fender spacing. Any opinions, ideas or experince.
I don't believe there are any spacers available for the rear fender. But if you read the AMG wheel install document for 8.5" wheels on a 124 (click here), look at pages 9-11, particularly sections 4.1 and 5. That shows the rear fender getting moved out (4.1), and also the fender lip getting fully rolled (5). It's also possible you have the wrong wheel offset and/or wrong tire size (you didn't mention what you have). If you haven't rolled the fender lips, that is the first thing I would do...
M. Schneider (04-24-2021)
Old 12-28-2008, 12:14 PM
MB-boy's Avatar
W124
Thanks AMGDave.
Well in the back the tires are 245 40 17. What rubbs is the side of the profile with the fender lip.A little but enough.
I saw the procedures for the back fender spacing but I think its not correctly explaind. This is because it tells you only to cut 200mm in a straight line, but what about the inner panel? !!!!its also attached!!!!
I thought that this fender spaceing would make the car look a little different than usuall. Im thinking of doing this but there is that problem with the back fender. What do you think.
Old 12-28-2008, 12:41 PM
  #32
MB-boy's Avatar
W124
Also, anybody have tips or opinions for good fender rolling.
Old 12-29-2008, 01:02 PM
  #33
AMGDave's Avatar
300D, 500E, E420
Yeah, I noticed the document was a little vague on exactly how to modify the rear fender! Strange, huh. I really am not sure what they're trying to do there. Your 245 tire isn't bad on the rear, I think with a proper fender roll it should work ok. The nicest unit I know of is the Eastwood tool, click here for more information on it... you might be able to rent one from a forum member? (I don't have one, sorry!)
Old 12-29-2008, 01:14 PM
  #34
MB-boy's Avatar
W124
Jajaja Wierd isnt it. Well thanks AMGDave. Im going to be rolling the fenders and then lowering the car. I think that will fix up the problem. Well about renting the tool... Im a little far from the US. I live in Europe so im going to have to build one. Looks easy, so no big deal about that.
About the rear fender spacing... I think the procedure should be rivised before anybody tries to do it that way (It dosnt look correct).
If anybody knows how to do it correctly, please post the procedures and some fotos. It will be very helpfull for alot of people.
Old 03-29-2009, 11:16 PM
  #35
SirTweakAlot's Avatar
1993 400E
This wheel package will be hard to duplicate.
I wonder if their AMG or Brabus
Old 03-31-2009, 09:29 AM
  #36
STLe320's Avatar
95 e320...sold the rest
Don't post that in this thread. You already made a thread for it, and honestly there was no significant point to that either. This is to help people, not to try and be funny..
Old 04-08-2009, 03:32 PM
  #37
CakeDaddy's Avatar
Silver CLS550, Blk M45, Lexus GX470 & an endless fleet of Avis Premium Rental Cars
Can someone throw me a bone on 225/40 18x8 et42 offset for the w124 (e420). Will they fit without issues?
Old 04-16-2009, 06:00 PM
  #38
YNVDIZW124's Avatar
lots of cars
^^ Yes, you might want to run a 3mm spacer but you don't really need to.
Old 08-23-2009, 08:53 AM
  #39
romeovictrbravo's Avatar
mercs.lots of em!
How thick is the suspension stop washer that is supposed to limit the upward movement ?
Old 08-27-2009, 11:46 AM
  #40
AMGDave's Avatar
300D, 500E, E420
The wheel will be very close to the front strut on the inside. I'd run 235 tires on an 8-inch wheel... if you lay a straightedge across the face, it will touch the wheel before the tire with 225's (unless they have a "rim protector" design). Shouldn't be any problems in the rear. But you will probably need to roll the fender lips all around, and maybe install the fender spacers up front... I'd recommend reading this AMG document with more info.
Old 08-27-2009, 11:47 AM
  #41
AMGDave's Avatar
300D, 500E, E420
Old 08-27-2009, 12:11 PM
  #42
Saijin_Naib's Avatar
1990 300ce 24v I6
Are both the stop buffer and the travel limiter still available? Would these be beneficial in conjunction with H&R Sport Springs/Bilstein HD or Sport shocks or..?
Old 03-10-2010, 08:22 PM
  #43
jmon01's Avatar
1986 300e
300e wheels
Is there any way to run 16 7.5 et51 cl500 wheels with p235/60hr16 tires on a 1986 300e
Old 03-18-2010, 08:29 PM
  #44
Brian_I.'s Avatar
w211 & w124
How about p205/60r15, 45 offset from a late 90's w202 on my w124?
Please help as I'm about to buy these off of Craiglist...
Old 04-01-2010, 08:59 AM
  #45
spetz's Avatar
1994 E220 Coupe
What if the car is lowered?
Will it scrub if the wheel size and offset is as per the chart?
Old 05-08-2010, 12:41 AM
  #46
YNVDIZW124's Avatar
lots of cars
People, just roll your fender. You'll need a 2" thick round piece of wood or a hammer handle, and a heat gun. You can do 18x9 on the rear with a +40 offset on 255/35/18s with rolled fenders. There's no massive fender rolling involved and we are not talking about pulling fenders either. If you don't want to do it with the wood handle, buy a eastwood fender roller.
Old 05-08-2010, 01:05 AM
  #47
edcarls's Avatar
97R129-01W163-94E320-93500E
What is the width?
With 45 offset the width should not be more than 7.5" or it will rub against the strut. You can remedy the high offset by installing spacers. For 8" width - 45 ET, 10mm spacer would put you close to the original spec, which IIRC is 7" width- 44 ET.
Old 09-15-2010, 03:20 PM
  #48
luvMB's Avatar
1994 E320
Does anyone know who sells the best amg style rims at a reasonable price?
Old 02-18-2011, 07:31 PM
  #49
JSe420's Avatar
1994 E420
Need a bone thrown my way.
Really hoping I can get these to fit.
18x8.5 et38??
Old 02-19-2011, 12:31 PM
  #50
ZorroAMG's Avatar
Enzo, my Benzo
I always forget, does 38 stick out further or less than 35? If more then prob not cause I run 18x8 et35 on a LOW suspension and mine are CLOSE. The back may fit, front most likely will be an issue.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: definitive wheel fitment guide for w124 pdf
