Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W124)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-13-2009, 06:58 PM   #1
gorillajin's Avatar
Drives: 1994 e320 sedan
How to check bad fuel pressure regulator?
Hi,
Does anyone know absolute way to check a FPR?
I heard that if I can smell fuel from the vacuum hose connected to FPR, means bad. However, I want to know if there is another way to check.
I don't want to do any guess and keep changing wrong parts.
I have changed a fuel filter, OVP, plugs and wires due to cold starting issue.
Thanks.
To remove this ad, register today or login if you already are registered!
gorillajin is offline   Reply With Quote
Old 10-13-2009, 10:45 PM   #2
Drives: 1994 E420
What you need is a vacuum hand pump with a gauge on it. Once you have your pump, hook it up to the fpr by simply connecting it with a small peice of rubber hose (but make sure its tight and doesnt leak) and see if it holds a vacuum. If it doesnt hold a vacuum then its bad.
JSe420 is offline   Reply With Quote
Old 10-13-2009, 10:59 PM   #3
gorillajin's Avatar
Thank you for the reply.
Where can I get the tool? Can I rent it from some auto parts store?
If you have a picture of the tool, please let me know.
Or if it's that easy, should I just ask a mechanic to do it? I am sure it will be either free or $20...
Thanks.
Old 10-14-2009, 04:32 AM   #4
appatula's Avatar
Drives: 95' AMG SeeThreeSix
Send a message via AIM to appatula
http://www.harborfreight.com/cpi/cta...emnumber=39522
Very useful troubleshooting tool. So many things on these cars are vacuum actuated, including most of the climate control components, door locks etc.
Also a generic version:
http://www.harborfreight.com/cpi/cta...emnumber=92474
__________________
|_1st-1980 280CE=TOTALED_|_2nd 1999 C280=TOTALED(rollover)_|_Current 1986 300E 160K_|_1995 AMG C36 145k_|
Visit RHW's, aka Rich's Website For More Pics!
appatula is offline   Reply With Quote
Old 10-14-2009, 12:42 PM   #5
gorillajin's Avatar
Thank you so much for the link. I will buy it today, and post here how is my FPR.
Old 10-14-2009, 02:41 PM   #6
gorillajin's Avatar
I got the tool, and tested the FPR.
It hold compression just fine. I guess FPR is ok.
Now what should I check?
As I said, changed OVP, fuel filter, spark plugs&wires, and FPR is fine.
Can this be ignition coil?
Tags
1986, 1994, 300e, bad, check, e420, find, fpr, fuel, pressure, regulator, smell, test, troubleshooting, vacuum, verify
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
