300e Sunroof STUCK!
Old 11-23-2010, 10:06 PM
mercedesman99's Avatar
1990 300e
300e Sunroof STUCK!
i have a 1990 300e and the sunroof is stuck in the Up posistion and will now go back down to shut or slide. Jammed, broken what should i do, and how do i take off the sunroof headliner, (not full headliner) thanks
Old 11-24-2010, 10:59 AM
ZedStyle's Avatar
Youngtimer
there's a manual crank in the trunk, should be on the driver's side (if you are LHD) behind the carpet, near the antenna gadgetry
Old 11-24-2010, 03:18 PM
BlackStar Stig's Avatar
W124 230E 1990
I have a similar problem with my sunroof, but in my case the wire has broken inside the roof.. The roof was also tilted up, but I got it down to shut position by simply pressing it down by hand from outside the car. Very carefully, and each side evenly as it started to come down. I finally got it shut.
But how to get access to the wire to change it I would really love to know also.. As it is now it won't move anywhere with the wire loose inside the roof..
Old 12-15-2010, 05:28 PM
1990 300e
this is reallly helping thank you you guys, and i think the wire broke inside mine because it wont do anything and its stuck in the up posistion but i will try to figure it out but if worse comes to worse i will take it to a shop... sadly
Old 12-15-2010, 08:36 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
http://okiebenz.com/pipermail/merced...ry/027261.html
thank AMGDave for that one.
Old 12-27-2010, 06:49 PM
hineywineries's Avatar
It changes all the time
Originally Posted by rivcal4life
That was an excellent write up with incredibly detailed photos. I commend anyone who has the tenacity to tackle a project like this. The slider pop-up sunroofs are very difficult to repair and align properly which is why I charge $800 to do the job. Again my hat's off to the guy who posted this repair.
Old 12-28-2010, 03:22 AM
Yeah, Dave is awesome! I used that walkthrough to successfully repair my sunroof, which was non-op when I bought the car.
Old 12-30-2010, 02:00 AM
zach1328's Avatar
e400
Yeah definately avoid taking it to a shop. Unless you're willing to pay a bill thats probably going to be over $500.
The shop my car always goes to won't even try to fix my sunroof for me. They say its too hard and expensive, and the guy specializes in older European cars which means its probably pretty hard if even he won't do it.
Mine still goes up/down, but sadly wont go forwards or backwards. I really wish it still worked, i love sunroofs and can't stand the fact it doesn't work.
Goodluck with the repair, hopefully you can manage it on your own and avoid the LARGE bill from any shops.
Old 07-03-2014, 02:22 PM
AngelaInAbilene's Avatar
1993 300e
Just what I was looking for! Mine got stuck in the up position last night and I definitely did not want to go 165 miles to the dealer. Thanks!!
Quick Reply: 300e Sunroof STUCK!
