FS: Mercedes w124 parts 300CE 300E mechanical electrical interior exterior - LA 90068
Old 03-01-2011, 03:46 AM
fredtga's Avatar
w202
All prices OBO, locals can pickup and i can be reached at 818-284-7611.
I'm in Hollywood, CA 90068.
- ABS pump: $60
- ABS sensors (front): $20
- vac hose brake booster (includes valve): $10
- brake master cylinder: $30
- A/C compressor: $60
- radiator: $60
- A/C radiator: $40
- fan shroud: $20
- air filer housing: $40
- air (smog) pump: $40
- beru / bremi spark plug wires: $40 / set
- various brackets, rubber hoses, smog related hoses: $5
- camshaft sensor: $20
- camshaft magnetic pickup: $20
- cooling fan clutch: $40
- ignition coil: $30
- coolant expansion bottle: $20
- crankshaft sensor: $20
- cruise control servo: $20
- motor oil dipstick: $10
- cylinder head front cover: $20
- motor plastic trim (front): $20; spark plug cover: $30
- fan: $10
- fuel lines: $20
- fuel pump assembly: $60
- complete m104.980 engine wiring harness: $200
- ignition components, sparkplugs, cap, rotor: $80
- idle valve: $30
- injectors: $60
- intake manifold: $40
- engine mounts: $60
- o2 sensor: $20
- valve cover: $80
- water pump: $60
- brand new in box water pump: $100
- washer fluid bottle: $20
- belt tensioner: $40
- oil filter housing: $40
- throttle body: $40
- fuel distributor assembly: $100
- distributor fuel lines: $40
- various plastic shrouds and shields: $5
- front shock suspension top mounts brand new: $80
- shock rubber boots: $20
- 722.4 transmission (35k miles): $600
- clutch and pressure plate (m103 m104): $60
- flex disc: $20
- shifter assembly: $60
- transmission xmember: $20
- transmission mount brand new: $30
- abs unit: $40
- belt feeder units: $20
- cluster relay: $10
- combination switch: $20
- comfort relay: $20
- cruise control lever: $10
- cruise module: $20
- switches: defog, hazard, seat headrests, rear window, mirror, headlight, rear light, recirc, steering adjuster, spk vol: $5 / each
- dome light: $10
- seat belt feeder: $40 / each
- m104.980 ECU: $100
- light control unit: $20
- map light: $10
- MAS unit: $60
- OVP relay: $20
- pass seat switch: $30
- SRS ecu: $40
- sunroof motor: $60
- trunk solenoid: $20
- vac pump: $60
- window switches: $40
- antenna: $50
- exterior coupe trim (black - complete 6pcs): $100
- passenger door (coupe black) : $100
- fenders: $80 / each
- gas cap: $10
- gas door (black): $20
- exterior coupe gray trim pieces (4 pcs): $60
- headlight lower trim (no wipers): $30
- jack: $20
- complete lock set with key: $80
- passenger outside mirror: $50
- rear passenger side window complete assembly: $80
- rear bumper: $50
- side skirts: $80
- tail light inner cover: $20
- factory tool set: $40
- exterior chrome trim pieces: $10
- coupe trunk (will NOT fit sedans or convertibles): $50
- wiper assembly: $40
- 3rd stop light: $10
- C pillars: $10 /each
- stainless steel trim (coupe): $5
- dash: $60
- various dash trim pieces: $5
- passenger front door panel: $30
- interior roof handles: $20
- headliner: $20
- rear headrests: $60
- rear headrest drop mechanism: $40
- interior rear view mirror: $20
- mercedes interior mats: $40
- middle sunvisor: $5
- A pillars: $10 / each
- lower front kick panels: $5 / each
- rear side window trim: $10
- door lower sills/trim (coupe): $10
- rear arm rest (folding): $40
- rear seats: $80
- speaker system: $40
- trunk mat: $10
- front and rear seatbelts: $80
- becker radio (leaking LCD): $40 / each
- complete Bose speaker system: $80
- dash grills: $10 / side; $20 / center
- console wood trim: $20
- hazard button : $20
- w202 front grill: $50
- w201 a/c compressor relay: $5
- w201 2.6 6cylinder EZL: $80
- e320 non ASR throttle body: $80
Old 03-01-2011, 11:40 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Hey Fred, about how much life do you think the O2 sensor has left to it?
Also, do you have the throttle position switch, or is that integrated into some other relay?
Old 03-03-2011, 09:13 PM
fredtga's Avatar
w202
pm-ed;
headlight non-wiper trim and air intake shroud sold
Old 03-23-2011, 11:47 AM
dtsdig's Avatar
2016 E400 4Matic, 1994 Mercedes Benz E320 Sedan (Sold), 1995 E320 Wagon (Sold)
Looking for interior parts
Hello, I'm looking for the trim piece that surrounds the driver's seat belt buckle near the center console. Do you have interior parts? Thanks!
Old 03-23-2011, 02:10 PM
fredtga's Avatar
w202
only parts in the pictures are available
http://www.furi-dorifto.com/sale/mercedes/
Old 04-07-2011, 08:42 PM
fredtga's Avatar
w202
Updated list:
- ABS pump: $60
- A/C radiator: $40
- fan shroud: $20
- fuel lines: $20
- idle valve: $30
- injectors: $60
- valve cover: $80
- water pump: $60
- 722.424 transmission (35k miles): $600
- flex disc: $20
- abs unit: $40
- switches: defog, hazard, seat headrests, rear window, headlight, rear light, recirc, steering adjuster, spk vol: $5 / each
- dome light: $10
- map light: $10
- MAS unit: $60
- OVP relay: $20
- SRS ecu: $40
- vac pump: $60
- gas cap: $10
- exterior coupe gray trim pieces (3 pcs left): $20 / each
- jack: $20
- rear bumper: $50
- side skirts: $80
- headliner: $20
- rear seats (one backrest only): $40
- trunk mat: $10
Old 07-17-2011, 11:35 AM
0-60Motorsports's Avatar
W124 E280 95
Do You have the hazard switch and side mirror controller for the W124 1995? PM me price shipped to NY11413 for either of them or both of them.
Old 07-18-2011, 07:38 AM
stormtigers's Avatar
88 W124 300CE
1. RH side rear passenger window switch and mounting surround.
Got plenty of switches but no surrounds.
2. Instrument Cluster ? 240km 7000rpm economy guage (not compulsory)
3.exterior mirrors ? after rectangular drivers side electric and left side electric rectangular if this is 95 model + controlling switch for adjustments
Postage to Australia expensive I know - but keen if you have the bits
PM me if you have anything in there
Cheers
Old 07-18-2011, 02:37 PM
fredtga's Avatar
w202
the only available parts left can be seen here:
everything else is gone
Old 07-26-2011, 04:48 PM
fredtga's Avatar
w202
many parts still available
Old 07-26-2011, 05:42 PM
halman2228's Avatar
PM Sent
for some interior bits.
Regards,
Kevin
Old 10-24-2011, 12:49 PM
fredtga's Avatar
w202
Old 10-24-2011, 01:57 PM
88 W124 300CE
Good OVP and working antenna ?
Old 10-27-2011, 10:54 PM
neanderthal's Avatar
PM'd you.
Old 10-28-2011, 05:14 PM
fredtga's Avatar
w202
OVPs and antenna are sold... how can i edit the original post to remove sold items?
Old 11-09-2011, 11:39 PM
Dysphoria's Avatar
'89 300CE
Can you ship to Canada?
Old 11-10-2011, 02:58 AM
fredtga's Avatar
w202
A/C
yes, i can ship to canada
Old 12-13-2011, 10:26 PM
rlj1117's Avatar
96 C280 ,83 300SD , 94 E320
do you still have transmission 722.424 ? what would shipping be to 28339 ?
Old 12-14-2011, 12:45 AM
fredtga's Avatar
w202
transmission is sold
Old 12-14-2011, 09:38 AM
rmnacamo's Avatar
1995 E320 Convertible
Parts for Sale
I have a 1995 E320 convertible, and it needs a rear bumper. Can you send me a picture of your rear bumper and whatever other pieces go with it?
Old 01-05-2012, 11:51 PM
MarioC55's Avatar
2005 C55 AMG Silver Bullet
so my offer on the defrost button is $5
hit me up if its around
marioaias@aol.com
949 300 3967
Old 01-06-2012, 01:42 AM
fredtga's Avatar
w202
email sent
Old 02-10-2012, 12:22 PM
DennisBenz's Avatar
1993 Benz 300CE
looking for 1408202526
Im looking for the belt feeder for a 93 300CE part number 1408202526. Would you happen to have one? I am in London, Ontario, Canada, do you ship to Canada?
Old 02-10-2012, 01:19 PM
funkgab's Avatar
1987 300E, 1995 C280
which car did this come out of?
i have a 93 300ce with the updated 3.2 m104
stuff i need
-o2 sensor (how much life?)
-spark plug wires
-brake booster line (vac hose)
-smog pump/smog hoses
-window washer bottle.. maybe pump too, not sure if its bad..
-front suspension shock mounts, where are yours from? meyle hd?
-shock boots.. (what are they for)
-convience relay (does it work with my car?) /combination relay is it? (i have the one touch windows as it is a 93)
-headlight switch
-ecu plastic cover
-CE windows/windows regulator
-front driver side window trim
-front window switches
-front seats
-front armrest
-storage box
-maybe rear seats, but i rarely use mine
-seatbelt bringer covers (you know the thing when you open the back window)
-seat switches
-driver side mirror glass
-rear view mirror
shoot me a pm or reply directly, i live downtown so i should be able to pick it up
Old 02-14-2012, 12:56 AM
Kimmy's Avatar
1991 Mercedes CE coupe
Hi, I realize this may be a longshot but I was wondering if you still had the rear view mirror?
Quick Reply: FS: Mercedes w124 parts 300CE 300E mechanical electrical interior exterior - LA 90068
