what power steering fluid is best recommended?
Old 04-14-2011, 07:09 AM
D4RK NiNjA's Avatar
E 420 mercedes
My car makes a loud noise, power steering fluid is low but before a fill it up i would like to kno whats best to use.
Old 04-14-2011, 06:42 PM
Quicksilver500's Avatar
1992 Mercedes-Benz 500E
Benz factory fluid. That was easy
Old 04-26-2011, 08:48 PM
larryj's Avatar
2004 SLK 230, 1992 300E & 400E
And ONLY Benz factory fluid...........
.........probably why you have the complaining power steering fluid pump is that someone (not saying you, but....) someone has been filling it up with NON Benz fluid. Must flush all that old bad stuff out, turning steering lock to lock with the engine running, sucking the old fluid out with your wife's (or significant other's) turkey baster. Make sure and remove the filter from the reservoir before doing this. It'll take quite a bit of fluid to get all the bad stuff flushed out sufficiently.
Get on the net, order, say, 3 containers of fluid and use them all for you need to run this removal process several times (start engine after removal of filter turning steering all the way right and then all the way left then center it and remove the fluid in the reservoir, refill and then do it again and again and....well, you get my drift).
autohausAZ will have the fluid AND the filter. www.autohausaz.com or somesuch.
Quick Reply: what power steering fluid is best recommended?
