Engine Serial number help.
Old 03-25-2012, 11:21 PM
chichie320's Avatar
1995 E320(daily driver), 2005 S4(summer toy)
I believe I may have the number that should the engine serial number but I just want to make sure. I found a post online that says there is a list of number by the radiator when you open the hood. The only numbers I see that start with 12, are 124032 12. Would that be the correct number that I am looking for? My pulley is making noise when the car is either idling or stopped and I want to order the right one. I don't know if it may help or not but, my car is a 1995 E320.
Old 03-26-2012, 12:10 AM
stormtigers's Avatar
88 W124 300CE
VIN number should reveal all about your vehicle.
It should look like WDx12403212xxxxxx
But from what you have provided thus far your vehicle should be :
Model W124 > 300E/E320 Years 93-95 Chassis No 124.032 Engine No 104.992
Hope this helps !
Oh if your really interested - have a read of this page at Autohausaz
http://www.autohausaz.com/mercedes-a...n-numbers.html
then go to this website and put your full VIN number in and it should tell you the delivery status of your vehicle when it came from the factory.
http://www.neoriginal.ru/cat/mb/
Old 03-26-2012, 04:01 PM
chichie320's Avatar
I looked at the VIN on the car and its WDBEA32EXSC271256. So now how do I know what the actually engine serial number is?
Old 03-26-2012, 04:42 PM
88 W124 300CE
Which pulley is it making the noise (photo if you have one) ?
The majority of retail parts stores will interpret your parts requirements by using your VIN No anyway.
Old 03-26-2012, 05:45 PM
chichie320's Avatar
im not sure if its the tensioner pulley or the idler pulley, either way still need a engine serial number in order to order the correct part.
Old 05-31-2015, 02:17 AM
MelanieSAJames's Avatar
SLK 350
Need to find Engine Number NOT VIN
I know my VIN number but now I need to find my Engine Number.
I need it due to a defect thats been reported in my model type year and engine size. They gave engine numbers that are having the issue I need to check mine against the list.
I need help on where to find the Engine Number.
Old 05-31-2015, 05:22 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Post your VIN!!
Old 06-01-2015, 04:11 AM
SLK 350
Originally Posted by Plutoe
Post your VIN!!
VIN: WDBWK56F76F085761
Old 06-01-2015, 07:06 AM
Plutoe's Avatar
1999 E300TD
The car is a SLK350---272.963--engine number 30 111099
Old 08-18-2015, 10:23 PM
rapri's Avatar
SLS63 Black Series
I have an engine number of w124 but not sure what the chassis
Please help,
I found a w124 conversion, without an original vin number. I suspect the car is conversion. All i have is the engine number and is there anywhere or website i can find out what engine it is? Thanks
Old 08-18-2015, 10:27 PM
rapri's Avatar
SLS63 Black Series
The engine number is 1199741200475818, i suspect is the 500e.
The following 2 users liked this post by rapri:
Amdbagory (12-06-2019), jylee (07-06-2016)
Old 08-19-2015, 06:55 AM
Plutoe's Avatar
1999 E300TD
That's not an MB engine number---help your self with the correct information!!
Old 10-01-2015, 09:29 PM
ipewpewuqq's Avatar
2007 c230
VIN check please
Can someone please run my VIN# for me please and tell me if I'm in the affected balance shaft problem range? Please and thank you. Just bought this car a few weeks ago and now getting P0016 and P0017 codes. 140k miles. WDBRF52HX7E024890
Old 07-01-2016, 12:59 PM
Dustin Terro's Avatar
Mercedes Benz c230 sport
m
Old 07-01-2016, 01:07 PM
m
Old 11-28-2016, 08:32 PM
fixitguy63's Avatar
07 E350
07 e350
I need to buy a water pump but I don't know my engine number. my serial number is wdbuf56x988254631
Old 11-29-2016, 10:15 PM
QVHK's Avatar
'90 300CE M103 Manual '93 Alfa 164 QV24 '05 Jaguar X350
Unless you believe that the car has had an engine transplant before (including dropping in a non-Mercedes engine), the VIN should help you find the parts you need. Try the following link, key in your car data as far as you know, and see if it works for you.
http://www.mbpartsworld.com/show ... key_product=7691670
Old 03-08-2017, 04:55 AM
adamu's Avatar
Mercedese benz c230 2007 model
Engine number location
Hi, I am also having trouble locating my engine number. my VIN number is WDBRF52H17F868469. any help please?
Old 03-08-2017, 07:47 AM
ohollenbeck's Avatar
04 E500, 00 SL500, 99 SL500, 94 E420, 92 500E, 92 500E, 92 300CE, 06 Lexus GX470
inputting your vin into Mercedes EPC, the engine no. = 272920 30 468903
Old 03-08-2017, 07:55 AM
adamu's Avatar
Thank you So much............ you guys are the best.
Old 04-20-2017, 01:21 PM
MBDaddyCakes's Avatar
1982 Mercedes 380SL
Cool Need Engine numbers for my two Mercedes!
Hey guys I could use someone's help getting the engine numbers for my two mercedes 380 SL vehicles. One is a 1981 and the other is an '82. I want to know if I can swap the engines and need the exact engine numbers to know if I can do it. Here are the two VINS:
WDBBA45A6CB013177
WDBBA45AXBB006599
Your help is much appreciated.
Old 05-02-2017, 06:27 PM
samdunlap's Avatar
2002 ML320 W163
How about this: I have the engine number but need the year
112942 30 589655 is the number from a used replacement engine for my 2002 W163 ML320. It was sold as a 2002 engine but SWEngines out of Tulsa won't provide me with the original vehicle's VIN so I have no way of being certain of the year. I've talked to Mercedes but they can only give me a range of years, 1998-2003. Is there any way to decode it to extract the year it was made?
Old 07-19-2017, 07:56 PM
thoailam7797's Avatar
2007 Mercedes S550
I have the vin number, but I couldn't find the engine serial number
Hello,
I have the vin number, but I couldn't find the engine serial number. Can someone please help me?
Thank you
Old 07-19-2017, 07:58 PM
2007 Mercedes S550
Hello,
I have the vin number, but I couldn't find the engine serial number. Can someone please help me? Vin number WDD2211561A084216
Thank you
Old 07-19-2017, 10:19 PM
samdunlap's Avatar
2002 ML320 W163
Originally Posted by thoailam7797
Hello,
Thank you
I found this site and it's pretty cool and accurate: www.vindecoderz.com/
Good luck!
Sam
Quick Reply: Engine Serial number help.
