Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W124)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-09-2012, 03:35 PM   #1
Drives: 1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
1988 300CE PURCHASE INFORMATION WANTED
I found a nice 1988 w124 300CE.
170k Miles
One owner
Good Service Records/Books
No Apparent Rust and or Repairs
Interior Very Nice No Cracks in Wood or Dash
Garage Kept
Everything Functions
It appears to be correct, maintained in very good visual inspection.
I have not put the car up on the lift as of yet.
I have been, and am an owner of a few W126's and C126's for years. I know pretty much the "Achilles Heel' on these cars.
I have little knowledge on W124's.
What is problematic in 1988 300CE'S or in other 300 W124's of the same vintage?
I will have my mechanic do a compression test, but only if it can pass the 'You Guys Know Group'.
Thanks Bruce
To remove this ad, register today or login if you already are registered!
BENZITCH is offline   Reply With Quote
Old 04-10-2012, 05:29 AM   #2
JayAre's Avatar
Drives: 86 190E 2.3 16V, 90 300CE (sold), 93 190 2.6 Limited Edition, 93 400E, 98 S500
Really nothing more than your experiences with the W126's. Same potential for HVAC evap failure, same suspect transmission delays from park to reverse.
M103 motors are very reliable. A design problem with original head gaskests causes gasket failure. Once replaced, you should be good to go..
Good Luck
Jayare
JayAre is offline   Reply With Quote
Old 04-10-2012, 07:02 AM   #3
Thanks for your info JayAre.
Old 04-10-2012, 05:35 PM   #4
Bump
Old 04-12-2012, 01:27 PM   #5
Drives: 1989 W124 300CE
Quote:
Originally Posted by BENZITCH View Post
Bump
Look for front timing chain cover leaks as well as the head gasket leak that someone else mentioned.
what kind of engine oil did the previous owner run on it?
Drive on the highway before you buy it!
visal911 is offline   Reply With Quote
Old 04-12-2012, 01:49 PM   #6
Thanks Visa It is always best to hear from people who own them.
Thanks Bruce
Old 04-16-2012, 03:08 AM   #7
stormtigers's Avatar
Drives: 88 W124 300CE
Few things I have had issues with on my 1988 300CE.
1. Single Fuse OVP can cause a few weird *** issues.
2. Front timing seal leak (common and a PITA to repair)
3. Cold start issues but found if I count to 7 slowly then start - 1st pop every time.
4. Speedo cable - speedo needle bounces at low speed
5. Fuel Gauge bounces when less than 1/2 full. Could be Pot in gauges or fuel sender.
Marvellous car love it to death !
__________________
1988 W124 Midnight Blue CE300 (220,000 kms)
Zender Body Kit (bumpers & skirts) / MB 'Facelift' front installed
LED Sports Mirrors / Eibach Pro Kit Suspension (lowered)
Ergon (Italian) E 17 inch wheels - 17x7.5""
Nexen 5000 235/45/17 Tyres
"Only two things are infinite, the universe & stupidity - and I'm not sure about the former." Big 'AL' Einstein
stormtigers is offline   Reply With Quote
Old 04-16-2012, 08:59 PM   #8
Thanks Stormtigers. I will check those out on Wednesday, when I see it.
Your car looks great also.
Do you have the aluminum fuses in the fuse box, or the copper ones?
Thanks Bruce
Old 04-16-2012, 11:14 PM   #9
Thanks Bruce
Originally aluminium but bought a complete set of copper off eBay and replaced them all.
__________________
Tags
1988, 300, 300ce, ce, ce300, common, delay, edition, leak, limited, mercedes, oil, problem, transmission, w126
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
