Sign in using an external account
| E-Class (W124) 1984-1995: E 260, E 300, E 320, E 420, E 500 (Includes CE, T, TD models) |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 1988 bmw 325i
sluggish 400e under load
#2 |
Sounds like the car is in 'Limp' mode....are there any lights on in the dash?
The car will put itself in this condition as a safety measure. The power and driveablility are cut until you can get it home or to a shop for a fix. You are going to have to see if pulling the codes from the CAN leads you to anything to fix or replace. Either a dealer or indy with a MB STAR diagnostic computer can pulls the codes...or you can make or buy a cheap LED blinker to retreive codes. Usually its an elcetrical proble that causes LH mode. Bad wiring harness (es), bad throttle actuator, dying alternator, or as simple as a brake light switch or nuetral lock-out switch can all cause LH mode. Check the wiring harnesess first, for this car from the factory they were designed as bio-degradable; and seem to start degraded upon delivery ! But really, the heat from these motors often cooked things like the underhood electronics and the plastic coverings on all the wires....turning them brittle and causing wire on wire electrical shorts and power spikes. Search here and on the web on 'W124 V8 Limp mode' and read up...it can be a pretty common problem on this vintage car. Hope it is a simple switch as a fix for ya'...new wiring harnesses and a throttle body add up to a couple grand alone.
__________________
"Meine Ehre heist Treue" 1992 Mercedes-Benz 500E 2003 Audi RS6 2001 Audi allroad 1986 VW 16V Scirocco 1981 VW Scirocco S-SCCA racer Last edited by Jim's500E; 04-20-2012 at 09:59 AM. |
| Tags |
| 1992, 325, 400e, 88, classes, fuel, limp, mbworld, mercedes, mode, problems, pump, pumps, sluggish, w124 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
