1987 300d om603 loud clacking/ticking noise [VIDEO]
Old 05-23-2013, 06:29 PM
Jollyroger054's Avatar
1988 300CE 160K & 1993 400E 115K
Hey guys I recently purchased a nice little 300d a few weeks ago with roughly 110k miles on it. This is my first diesel and my knowledge of them is quite limited. I've noticed a loud metallic clacking noise coming from the top end primarily when its idling and loudest when the engine is cold. The clack or tick is isn't consistent in frequency but is proportional to the rpm (if that makes any sense). Also the noise disappears with higher rpm. Because the noise is inconsistent (occasionally skips a beat) I don't think its a lifter tick, its also louder than any lifter tick I've ever heard. From a stethoscope I've narrowed to the valve cover somewhere near cylinder 1 or 2. There also is some hammering noise coming from the 2nd injector nozzle. I've read that the injectors can cause this type of noise what do you guys think? I'm still not ruling out lifters either.
To help here's a link to a video of my engine:
The noise is especially noticeable towards the end of the video after the RPMs come back down. It's a higher pitch clack noise distinct from the lower-frequency noises of the engine.
P.S. Don't mind the oozing fuel line on injector one, I've got some hose ordered.
Thanks Guys!
Old 10-20-2014, 04:25 AM
Jimej073's Avatar
1987 300D /w124/om603
I have the same noise. The clacking sounds. I have removed and replaced injectors with new ones with same results. Only thing that takes the noise out is when doing a diesel purge. During the purge the engine runs without the clacking.
Old 10-21-2014, 04:30 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Put one end of a coat hanger on the fuel pump and the other end on or in your ear-----what do you hear??(or simply purchase a sound probe and do the same thing)
Old 10-21-2014, 04:37 PM
Jimej073's Avatar
Thanks Plutoe,
I have had the IP rebuilt after first noticing the noise. I don't think its the IP. I'll have to use your recommended method to find the location of the noise though. Thanks.
I have to say that i first noticed the noise after getting work done on the cylinder head. I had the old cracked cylinder head removed and replaced. The problem was that by the time the work was done my car had been sitting for almost a year. The cracked head let water into the cylinders that caused corrosion. The bottom half of the engine was then removed and replaced with another om603 that had been recently parted from a car that was sent to a parts yard. When the car was returned to me is when i noticed the noise. I don't remember the noise before the work was done.
Old 10-23-2014, 01:39 AM
diesel88's Avatar
W124 300D 1988 W251 R280 cdi 2008
Noise?
Sounds just like mine, 360000km, non turbo.
Quick Reply: 1987 300d om603 loud clacking/ticking noise [VIDEO]
