Update on '86 5-speed 300e
Old 09-20-2013, 08:58 AM
ccb_v2's Avatar
1986 300E 3.0 5-Speed
Ok here is the latest in my fight with this 300e. Got car to run, has copper core plugs, new wires, new cap and rotor, checked fuel flow after pressure regulator, checked fuel flow through distributor and had to adjust the Electro-Hydraulic Actuator as its flow rate was around 800mL at first at WOT. Got it down to 300mL. The issue is that it starts but goosing the throttle causes the engine to die. I can get it to rev properly by manually manipulating the air flow flap with the throttle. I did the flow test by running fuel lines to little bottles, jumping the fuel relay to always run, and dropping the hammer, on the air low plate, to simulate WOT for 60 seconds. After 60 seconds I remove the hammer and measure the fuel. What are some other things I can check to troubleshoot this issue?
Old 10-02-2013, 11:19 PM
ccb_v2's Avatar
Well readjusted the flow to 1 liter at WOT. Now have better throttle response. Now a new issue... the oil pressure drops to 0 slowly as the car warms up and at that point the rockers start tapping. Is this an issue with the oil pump pickup slowly catching debris and clogging it, then settling when the car is off. When the car cools and is started again the cycle repeats... Should I flush out the oil? How does one do this, just pour it in with the plug out or use some solvent?
Old 06-27-2015, 05:47 PM
ccb_v2's Avatar
Turns out the timing chain tensioner was WAY to high and chewed up the guides. Switched to a 2.6L engine block and cylinder head from a '93 190E and plugged the exhaust port that would go to the air pump. Moved everything over from the 3.0L and got it back in the car. The motor isn't getting fuel. It runs with a can of starter fluid sprayed into the air speed sensor assembly. Tripped the fuel pump to run constantly and took off a fuel line going to injector #1 from the fuel distributor and with the air flap all the way open there is no fuel coming from the top of the opened port on the distributor. There is gas at the fuel inlet port on the distributor. Popping off the EHA shows gas there. I am hoping the distributor hasn't failed all of a sudden after the car sat over the winter in the car port... I tested the voltage at the EHA's connector and show 7v, and on my 190E it shows 13v. Not sure how much of a difference it can make. Any ideas are welcome. Tomorrow I plan on swapping the air speed sensor assemblies between the 300E and my running 190E to see what happens...
Old 06-29-2015, 01:53 PM
ccb_v2's Avatar
Update: Got the fuel distributor to spit fuel through to the injectors now. I swapped the Air Flow sensor assemblies back and forth and somehow it started working again on the 300e. *shrug* Car fires right up but stalls after 3-5 seconds. If I'm quick and get to the throttle lever and air flow flap in time I can keep it running by giving it just a hair of leverage on both, but once I release them it dies. It has a new OVP from eckler's and I've done the flow test on w124-zone-dot-com. New plugs, wires, cap, rotor, and keeps running with starter fluid. Any thoughts?
Old 07-11-2015, 06:35 AM
gatorblue92's Avatar
240D, 300E, 300TE
What brand OVP did you use? If its not a KAE, Kahler or OE Mercedes part its likely defective.
Old 07-15-2015, 10:23 AM
ccb_v2's Avatar
KAE brand.
Old 05-14-2018, 01:14 PM
ccb_v2's Avatar
Update: Swapped on an 89 motor and it fires up but runs rough. I had a 93 190e and pulled the resistor that hides behind the ECM and battery on the 300e to use in the 190e to resolve an issue with it running rough and the 190e is now long gone. Does anyone know what resistance that was?
Old 05-14-2018, 04:47 PM
ccb_v2's Avatar
Found it: 750 ohm resistor = 6 degree retard (standard in US car)
Quick Reply: Update on '86 5-speed 300e
