have a couple Questions
1991 300e 1997 Wide Glide
I have a 1991 300e I picked up a couple months ago an it runs fine but It has it quirk. First the driver side window won't roll up or down took the door panel off the motor is running looks like it is tangled up can it be rewind??
Second this just started the driver door lock will not turn to lock or unlock the doors but the passenger side an trunk will lock an unlock with no problems any body ever have this issue. An third is that the climate control system is not working I don't know if it has anything to do with the stereo being ripped out of the car ?? Any help would be greatly appreciate.
Thanks Hazz72
Thanks Hazz72
First question----no, need new regulator
Second question-----use WD-40
Third question--- not stereo related----run the self guided test and post the actual values---see stickies for test
Have a couple Questions
thanks found a new regulator and motor on ebay new for I think $50 so I am getting that and keeping the old motor for a spare. I tried WD40,Nuts Off, white grease in the lock no good feels like the key is going to break took out the alien key an the door panel off to see if there's something binding an no luck with that.
Hi,
We carry the new window regulator for $35.43 with a one year warranty:
Here is a link to our site:
AutohausAZ - Window regulator
Disclaimer: Make sure to check the year and model of the vehicle before
placing the order.
placing the order.
