climate control not working 1991 e300
1991 300e 1997 Wide Glide
has any body have a problem with the climate control not working an know where I can get a wiring diagram or know what color the power wire is so I can start there .
Thanks Hazz72
Thanks Hazz72
Hey you are starting at the wrong end of the mule----read up on the 16pole diagnostic unit on your car----then get a pulse counter---then post the results of the AC pulse test---thats a starting point!!
Thanks will do I found that the hack before me put a after market stereo an looks like he hack what ever wires he though was a hot an a ignition hot. I found out by accident when pulling out the stereo wires I found out he had a lot unplugged. but I found out that there's a 4 pin plug that is almost on the floor with no connection on it an I have 4 wires thar have been stripped colors are as followed 1 black wire yellow strip 2 red wire white strip 3 grey wire blue strip 4 brown. An he also broke on of the connectors on the fan motor. Glad to see he was a mechanic he told me to just run a new hot wire.
