brakes over heating
Old 10-13-2014, 07:42 AM
ElieSednawi's Avatar
w124.031 300e 1991
brakes over heating
Hi
i am facing this problem in my 300e 24 valva
my brakes get extremely hot and makes a queasy sound as a result for that i lose totally the braking power.
i did in 1 year around 20,000 KM in which i changes the braking disks twice and the pads 6 times (all original parts). and it is always the same problem.
is it a main problem or what?
any help?
Old 10-13-2014, 10:07 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
In all this screwing around with disc's and pads did you ever think of checking whether the calipers were function correctly!!
Old 10-13-2014, 12:04 PM
w124.031 300e 1991
Thank you for you reply.
yes it was checked and it is working fine (according to my mechanic!!!)
Old 10-13-2014, 01:16 PM
Plutoe's Avatar
1999 E300TD
Think about this for a day--what's in the system-----what turns---what braking action causes the car to slow down---therefore if you never actuated the brake pedal nothing would wear!!
However if you actuated the brake---- pressure would move the brake pad toward the disc------when you remove the foot from the brake pressure is reuced and the caliper returns the pad to its starting point------you have a issue with calipers---Change mechanics!!
Quick Reply: brakes over heating
